Question about Palm Vx Handheld
I do not have software disk
I am using my daughter's Palm Vx, she lost the disk. It is starting to act up and I want to use the hotsync to download all of my data before anything happens, my life is in there!!!!!
    Master:
  • 473 Answers
Download Palm Desktop Software installer from www.palmone.com -- just go to support - downloads.
Posted on Sep 12, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
Software download to handheld
You must have Palm Desktop installed on your pc. You must have a serial cable from your pc to your handheld. You must have hotsync running on your taskbar. You must download the software to the Palm Desktop and then hotsync your Palm with the pc. You may not be starting the safe hotsync in the start menu before pressing the hotsync icon on your Palm. If it's not that, your pc may not be recognising your Palm device or you may not have your serial cable securely hooked up, or you may be trying to download software that's not compatible with your device. You also have to reset your device after installing most software. Make sure you have enough memory to hold the software.
Apr 02, 2008 | Palm TX Handheld
Connection is lost (6410)
First open the HotSync custom menu, start changing conduits to do nothing. Work your way down the list until you end up with a complete HotSync. If you still have the 6410 error, unplug the USB adapter, replug and try your HotSync again. The USB adapter may be the week link in this equation.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
Hotsync
Had the same problem, had to send it to Palm for repair/replacement for $100.
Sep 12, 2005 | Palm Vx Handheld
Hotsync Error 4364; How do I find task which supposedly has been modified by Outlook and Palm?
Are you synching your Palm V with Outlook using the supplied software (Chapura PocketMirror stadard edition)? I have never heard of this error - it is not documented on any website I could find including that of chapura who usually are very thorough.
Sep 11, 2005 | Palm Vx Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Hard reset and recovering lost outlook data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 71 Handheld
How do I HotSync a Palm Vx with Outlook 2002
You'll need a softwre like Chapura PocketMirror that you probably have on your IIIc CD-ROM
How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I have a T5 and assume it's the same, but try putting your software install disk in your new PC at work. One of the options is to change sync with Palm Desktop and Outlook.
Sep 11, 2005 | Palm m505 Handheld
Palm Vx Handheld Logo
35 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
