Question about Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier
Riadio code My VW jet ta radio doesn't work since my battery was disconnected for clutch repair. Any info would help. thank you.
  • 1,586 Answers
Does it say "safe" when you power it up? If so, you need to enter the unlock code. It should be in your owner's manual packet. If not, you have to go to the dealership with photo ID, registration, and title. They can look it up based on the VIN number of the car. They may charge you up to an hour's labor, so be sure they write it down for you in the event you have to disconnect your battery again in the future.
Posted on Sep 01, 2008
Hi, my Nissan qashqai went in for a clutch repair when I got it back my radio is not working. It wants me to put ina code and i dont even know how to do that nevermind what the radio code is?
Return to where you had the clutch repair done and have the "mechanics" fix the problem they caused by disconnecting the battery and then forgetting to reenter the radio code.
Jul 14, 2017 | Nissan Cars & Trucks
How do I get the code for my vw radio
I look on the bill from the dealer. It is normally on there so they can reset your radio when they disconnect the battery.
Mar 13, 2016 | Cars & Trucks
Radio won't work. reset battery and it works until you shut the car off, then won't come back on.
May be it needs complete reprogramming.
To reprogram the radio there is 4 digit code. That code has to be inserted, once these code is inserted, your car radio will get into its actual setting where you can set/select your radio setting.
Many a time's radio asks for the code after car battery is disconnected.
On some cases to retrieve the code its mentioned in manual or else car dealer is other option to get car radio code.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Dec 06, 2012 | 2006 Volvo XC90
I have a 95 vw golf replaced battery now radio no workie is there some kind of code i need to get it to work and where do i get it
When you disconnect the battery the radio needs a security code to reactivate it.
You can get this code from a local VW dealer using the VIN of the car (wil be on your registration document for the car) and the serial number of the radio. You will have to remove the radio from the dash to find the serial which is on a label at the back of the radio.
There may be a charge for this from the dealer. However, if you wish you can post up all numbers found on the label of the radio as some but not all of these VW radios can be decoded by serial.
If yours is one of these I will see if anything can be done so let me know.
Thanks for using FixYa.
Dec 19, 2010 | Car Audio & Video
Im looking for the raido code for my vw golf,,,, i changed the battery the other day and i need the code for the radio to work ,,, does any 1 no where i could get the code ..... its a gamma radio serial...
If it is a factory radio,you can contact a VW dealer(I think you need the VIN# also)and they will provide the code for free.Write down the code and method because anytime the battery gets disconnected that will happen and it does get disconnected for some problem checkouts other than battery or alternator.
Good luck! Greg
Sep 25, 2010 | 2001 Volkswagen Golf
There is a beeping noise coming from my Blaupunkt Nashville DAB35, how can i stop this?
is the beep sound only happen when you listen to Radio? or other source also have? because beep sound may generate on Radio station if TA is ON for traffic anoucement but that particular station do not have TA info, so Radio may beep during checking. You must go into Tuner menu list to off the function.
Aug 24, 2010 | Blaupunkt Nashville DAB35 CD Player
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
2000 VW Beetle - had to jump the battery and when it restarted the radio doesn't work and the fuses are not blown and it doesn't show SAFE or anything on the radio.
2000 Beetle radio has a 10amp fuse at its rear left. have to remove radio to get to it. removing and returning radio is not easy. let me know if you need help with that as i have done this repeatedly on two different 2000 beetles and finally have it downpat. of course you need radio code, have found an article on how to disable VW radio anti-theft code but have not tried it yet.
Oct 09, 2009 | 2000 Volkswagen Beetle
Need advice on changing a battery on a 2000 VW jetta
I change the battery on my TDI by undoing the nuts in any order, positive first and then neg, or vice versa. If you happen to have a long wrench that can connect terminals, be very careful not to touch the other one, undo the neg first then. When you work on the positive pole do not touch any metal parts of the body, if you have not released the neg yet, otherwise you will see fireworks with the following fuse replacement.
When the batteyr is disconnected from the terminals the radio code will be lost. If you don't know your original radio code, you will have to go to the dealer and pay $105 for the code. Without that code the the radio will not work unless you have installed other than VW CD player
Jul 16, 2008 | 2000 Volkswagen Jetta TDI
Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier Logo
99 people viewed this question
Top Prime Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Prime Audio Player and Recorder Expert? Answer questions, earn points and help others
