My 1 and 1/2 year old Scott 37 inch LCD HD TV stopped working today. While watching the tv a loud snap like a firecracker occured and a green lightning like flash went up to the ceiling behind the set. The tv is totally dead now.Let it sit and cool off. Also put the plug in another socket. No extented warranty on this set. The question is the TV worth fixing when I can buy a Toshiba 42 inch for 900. Also if not worth fixing in your opinion or you think it is not worth the 70 dollars for analysis, what would you buy in the 37 t0 42 inch range. Aoso, would you buy an extended warrantyon . Thana new set. Thanks Tom Filloramo
  • 1 more comment
  • tfilloramo Sep 01, 2008
    This is not a prohection TV. This is a LCD 37 inch Scott HD TV
    You say buy a new LCD TV. Is it unusual for a LCD to self destruct in less than two years. How long does a good one last. would you buy an LCD, Plasma, or the old fashion tube. What would you buy for a brand name. I am so upset that a 1000 dollar tv craps out in such a short time. Please advise
    Still confused.
    Master:
  • 521 Answers
Go for the sony lcd televisions as they give the extended warranty .after the warranty is over you can claim for extended warranty .you have to pay some thing extra for this but that is worth if this type of accindental problem happens. but as a expert i will suggest you to please get your tv to the very local repair center in your area .they just need customers for their levilhood.they also bargain for the cost.and also u will get the warranty for the parts he replaced.as ypou just have to pay after the tv is repaired,then why not try before buying a new. if the parts are replaced why the problem will occur again and if occured there is a warranty for the parts.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 01, 2008
    Genius:
  • 2,035 Answers
This you could due the short of the current in the board or due high voltage in the voltage in the tv which is caused you this problem use a ,repair this will cost you 250 to 500 for the parts and labor cost will be around 200 $ ,instead you can buy new TV and then use the Surge proctor which will protect the TV any high voltage to prevent damage its within 50$ ,Please use this link to check the price:
http://www.nextag.com/protector-surge-tv/search-html
IF like DIY then I would recommend going to the following link and getting the service manual so you can see first hand disassemble instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck.....
  • 928 Answers
The TV in my opinion would cost around 400 to 500$ to have it fixed since most likely a board inside is burnt based on the description that you gave. Well If you have it analyzed for $70 it could be considered cheap if in fact only some loose wires may have caused a short or the power supply shorted, so having it checked may save you money. As for the extended warranty Yes I would buy it depending on the cost. If it costs more than 30% of the purchase price then never mind. So basically my suggestion is to have it checked first for $70 then if it will cost you more than 400 to 500 to fix then just replace it and buy the new one with an extended warranty if it does not cost more than somewhere around 10 to 20 % of your purcahse price.
  • Thomas Lim
    Thomas Lim Sep 01, 2008
    Honestly an LCD should not as you say **** out in such as short time. its built to last supposedly, mine has been in operation for about 3 years of daily heavy use. Im expecting it to go anytime. Honestly, I always go with Sony by choice and always LCD rather than plasma. It lasts longer.
  • 6,487 Answers
For my opinion I will just go in buying a new Toshiba 42 with extended warranty so what ever happen on that new TV you're sure that you can have it repair or replace anytime during the warranty and the extended warranty, but if you want to ahve the old TV fix you will spent big bucks for the repair labor and the parts that needs to be replace..
Hope that helps........
  • Mark Gil
    Mark Gil Sep 01, 2008
    I prefer getting a Plasma instead of a LCD tv, LCD TV should last 3 or more than years but not sure why yours just last for a year...
  • 19,396 Answers
If the model is a rear projection, the loud noise could have been the power supply or the lamp. Power supply is around $200, bulb starts from $400, add $100 or so for labor.
It is still worth, but won't be far from a price for a new TV set of same or better quality.
  • Ginko
    Ginko Sep 01, 2008
    If it is an LCD parts may be cheaper, unless LCD panel is gone, that is the only really expensive part.
    Fee for repair starts from $80 for diagnose the problem, $150/200 for a fix with no parts involved.
    And more likely $300/$400 in your case, as some component have probably shorted and blown.
    Check that it is not just the power cable that has shorted, if it has external power adapter check that this is still working, a replacement power adapter goes for $60 or so.
    Test also on a different power socket.
Pluged tv in made apop and now will not work at all its a 37 inch scott flat screen
The bulb may have blown or you may have blown something on the board.
Either way, the TV is broken and not likely to be worth repairing. 37" LCD TVs sell for under $500 regular price.
Mar 10, 2011 | Scott LCT37SHA TV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red lights
If your TV is less then a year old, i would suggest to call the vendor or manufacturer to have the LCD repair under warranty. Most electronics devices carry one year warranty.
The failure of your LCD is not related to any fuse since you're still getting some lights from it.
Good Luck.
Jul 09, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
