Question about HP PL4200N 42 in. Plasma HDTV
HP Plasma TV - Lost Picture
A few weeks back I turned on my tv and the opening "HP" initalizing screen was half black; then over the course of a couple minutes, the screen filled in so there was no more black blob, but it was as if I only had half the pixels, like watching tv on an old antenna set. I've heard the set just needs new plasma - is this true? If so, what is a good $ to pay and not get hosed.
  • turnerm7 Dec 23, 2008
    Mine has the same problem,
    After about 2 yrs of care free service. Too bad, I thought HP used to make quality products. Seems to me they are manufacturing the same garbage electronics as other outsourced companies. What ever happened to 'made in the US' quality products.
    If you have a solution, please let me know.
  • 36 Answers
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Posted on Feb 04, 2009
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Half TV screen is black
you have a bad Y Sustain board or X Sustain board
undo the back (if you know how to deal with electronics) and with the TV unplugged disconnect one of the board and turn on, see if works or not and try with the other one till find out wich one is.
Fosg2000, Rate me
Apr 13, 2010 | Philips 42PF9830A 42 in. LCD Television
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Samsung plasma TV, half screen is blacked out
Well, as per my last posting, I thought I would share. The problem of the bottom half of my 42 inch Samsung Plasma blacked out - meant a trip to the local TV repair shop. I have to say, they were great. I took it in and they were able to fix it after replacing a part - had my TV back in about a week. Cost was approx. $300. This was well worth it, considering how much I had paid for this TV only a few years ago. I had the repair done last month and so far, it's been great. Sorry, but I can't remember the name of the part.
Aug 10, 2008 | Televison & Video
Sanyo DP42746 42 in. plasma TV
Well I have the same problem with green light and no sound and no pix. After i opened it all up i checked the main power supply board and found all fuses good and the 12vdc side of the board dead. My best guess is this power board has many problems. All the driver boards for the screen are located on the perimiter of the screen. If you loose part of the power supply board you will loose part of functions of the tv. At this time i am looking to replace the entire power board. Will let you know the location and fix soon as i find it. jim jamesgibson@nycap.rr.com
Jun 19, 2008 | Sanyo DP42746 42 in. Plasma Television
Half Screen went black
Try to replace the Logic board.
Dec 17, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
HP PL4200N 42 in. Plasma HDTV Logo
958 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
