Question about Sony Cyber-Shot DSC-H1 Digital Camera
H1 out of focus above 7xzoom?
I have only had my H1 for about 1 week so still have loads to learn.I am probably totally missing something & looking completely dumb,so here goes! When i zoom in at approx 7 x zoom/above, the object goes out of focus.If then i switch to movie mode ,you can here the autofocus move & the focus is perfect/as normal,you are able to zoom in and out without a focus problem.Then switch back to any mode and the focus is still normal until you adjust the zoom. Putting the camera in movie mode ,then back again is the only way i can focus above 7 x zoom? Thanks keith
    Master:
  • 551 Answers
Very recently, we've been discussing some "macro" issues for the H1 .. Quite clear one has to respect "object to lens" distances :-) In a nutshell : from the full wide Z@x1 up to Z@x3, the H1 is able to lock focus from about 2cm/0.8" (maybe a bit less!) up to approx. 15-20cm/8" from Z@X3 up one needs to keep distance .. ie minimal is 90cm with the macro function enabled .. without that function the distance may be more than 1 meter for proper focus lock .. .. and sometimes one observes odd behaviour .. it locks focus at a position somewhere in between the above, but it is enough to half-press the shutter a couple of times and the focus lock is gone .. weird :-)
Posted on Sep 12, 2005
    Master:
  • 551 Answers
Try to use center or spot focusing mode. In the setup menu make sure the Auto Focus mode is set to Monitor (not Continuous). Retry the half-press of the shutter button if the picture is out of focus. Let go and try again. The camera should snap into focus very quickly. Also try to focus on something with high contrast. I hope this helps.
    Master:
  • 551 Answers
HI, are you sure that there is no conversion lens setting activated in the setup menu? It sounds like that to me. These modes limit the ranges. I hope it will help, otherwise you will have to bring it back.
2008 zetec Focus 1.8, slight miss fire when accelerating in fourth gear, pulling onto motorway yesterday and tried to accelerate and it was as if something was holding me back
A miss under load on a Focus is usually a bad or failing coil on one or more of the plugs.Also how old are the spark plugs?
May 08, 2017 | Cars & Trucks
I have a 70-300 mm for my E-520. It is barely a month old. If I focus manually, with the large 'grip' ring set at 300mm, the lens will only focus at 150mm even when focusing on a high flying aeroplane. In...
The lens is definitely faulty. Either return it to the retailer for an exchange/refund or send it to the manufacturer for a warranty repair. Of the options available, a warranty repair should be your absolute last choice.
Sep 30, 2010 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
My Sony H1 has stopped focussing.. It does not auto focus and cannot be manually focussed either
HI, you can just get the focus option back on your device by just resetting the Camera to the default settings.
Follow the steps below to reset your device..
Go to Setup-1 Menu
select Initialize
Select Reset the camera to defaults
Select OK or YES when it prompts.
this gets the focus option back on. .
Jun 29, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
It won't play Rome: Total war because a file is missing
try re-installing the game. if that doesn't work, you have to go back to the store you bought it at and try to trade it for a new one, because the game is missing an important start file, probably not able to be founddue to a virus or a scratch on the disc. if you cant get 1 for free, you have to buy a new one.
Jun 02, 2009 | Sega Rome: Total War Gold Edition for...
Rear projector tv rear blue projector wont focus
Look into the top of the tube. Probably has fungus growth. Do a search. I posted that solution many times this week for that. Normally, focus don't go out on T.V's by themself. Either the tube is bad or has fungus or the screen control is bad.....but very rare will focus part fail...usually brightness/screen is at fault. Don't forget to check the green tube as well when looking. Take the back off and see if your head will fit. If not, a large mirror will do just fine. Put something on with writing displayed....easier to tell that way.
Dec 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
Sep 21, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
SONY DSC-H1 focus problems
I think the reason for that is that you are using a wrong focus type. I recommend you using wide focus (not sure if named it right) and make sure you have your steady-shot function on. To change focus type, just find the button next to the shot-button.
May 02, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
H1 - blurry/soft pictures
I'm afraid this is more a learning curve in general photography :-) I know I also fell into that pit, after so many years of 35mm usage!, by believing at first that "digital" can do it all, well it can't fool general laws of photography/optics :-) .. once one has mastered that, things have a tendency to go a lot smoother :-)
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
76 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
