Question about Mitsubishi WS-65809 65" Rear Projection Television
Help me please b4 my fiance breaks it..
I have a i think 50in(maybe bigger) mitsubishi projection tv and we can't get the picture to stop rolling unless we shut off the t.v and unplug it and wait a few minutes. Then we plug it back in and it is fine for at least thirty minutes, then the picture starts rolling again. we have tried everything we can think of and nothing works. my fiance loves the t.v and so do i but he is getting frustrated with it and is thinking about throwing it out.. can u help ur my last hope.
  • krakdsanity Sep 01, 2008
    thanks i am going to get the model number tonight for you just to make sure... o and did i mention thank you..
  • 927 Answers
Good Day, krakdsanity;
It's an easy fix, but maybe not cheap. Not knowing the Model #, I would suspect; C2p05 100ufd 16volt off pin 3 of IC2P01 (9-volt regulator) both are on the signal board.You may not be able to repair yourself but you will know what's wrong when you call an an Authorized Service Center. Cost on your type TV varies but should be about $550.00 if they come to your home. Make sure you get a written estimate first. Good Luck,big IRISH.
Posted on Sep 01, 2008
  • MICHAEL MULLINS Sep 01, 2008
    When you do get the info you can e me directly at mmrkcar@yahoo.com. Good Luck, big IRISH.
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Diagonal lines rolling or showing on picture
I think that means your FMT brd is going out. you can have a mitsubishi authorized service center come out and send an estimate to mitsubishi for help on the repair, or have a service center come out and repair it, usually about 300-500 out of pocket either way
Mar 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Hitachi 50UX57B 50in Rear Projection Television picture not align
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Hitachi 50UX57B 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
PICTURE IS NOT ALIGNED HAVE TO TAP TV TO GET IT CORRECTED
Good Day;
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
