Question about Bose Lifestyle 28 System
Bose Acoustimas with error 10 - Bose Lifestyle 28 System
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Error 10 is either a disconnect from the audio input cable (check the pins on both ends) or the Acoustimass module has no power. Check the outlet etc. If resetting it (unplug both components for 30+ seconds) doesn't fix the problem. Call Bose for a repair.
Posted on Jun 21, 2009
I have a B&O 7000 connected with two passive loudspeakers and there are two other connecters forseen for active loudspeakers I wonder if it is posible to connect a Bose acoustimas 8 serie II to t
Just make sure they all have the correct impedance to match your system. Such as 8 ohm or 16 ohm. Sometimes the speaker inputs are marked with the correct ohm value
Dec 03, 2012 | Audio Players & Recorders
I have the bose 123 system. Where does the power
the acoustimas box has a power cable.
their is a cable from the acousimas (subwoofer) to the dvd plaver, the power supply is included in this cable
otherwise check site http://www.bose.com/pdf/customer_service/owners/og_321_2.pdf
Feb 15, 2010 | Bose (321GS) System
I have a pair of redline bose cube speakers and an acoustimas. I don't have cable for the connection. I would appreciate if someone help me showing diagram and which cable I should use it. Thanks
You can make a serial cable for it. All you need is a 15-pin d-type female connector and a bunch of speaker wire. Solder the speaker wire as shown in my diagram.
Sep 22, 2009 | Bose Acoustimass 10 III System
No sound on my bose acoustimas wave radio, all other indicators work
I would start to check from the audio amplifier ICs section. Most probably the Audio Amplifier IC faulty but there are many version of Bose Wave radio and therefore couple of Audio amplifier ICs have been used namely TDA 7374, TDA 7375 and more.
Jun 13, 2009 | Bose Wave Radio
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Audio problem - Bose Acoustimas
Go into the parameters setting for your receiver and make sure that your levels are at least matching all outputs. If this is not the case, suspect wiring or a problem with the amplifier. Oh, and last but not least, make sure that the receiver has at least the "speaker A" option switched on...accordianman
Jan 27, 2008 | Bose Cinemate Digital Home Theater System...
Bose Lifestyle 28 System Logo
714 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
