Apple Final Cut Express 4: Mac Logo
Posted on Jul 30, 2011
How to edit with final cut express from a flash disk
Anonymous
Level 1:
New Friend:
  • Contributor 46 Answers
  • Posted on Aug 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
46
Questions
0
Helped
11749
Points
69
Generally speaking you cannot do this. Flash disks cannot transfer data fast enough for video editing. You need to put the media files on a hard drive, preferable one with 7200 rpm (though some 5400 rpm drives will work).
1helpful
Canon Vixia HF 20 how do you get the files onto the mac
This camera stores the video using a unique method, and does not allow you to simply drag and drop the video files - you also can not easily find the camera and play the video real time to transfer it ...
You need a compatible software program, meaning the software needs to be compatible with the camera ... there are many available ... but if you are looking to buy software check to see if it is compatible with your camera before purchasing ... I wonder, what software will you be using to edit the video?
For example, you can use Final Cut Express. It will find the camera as long as the camera is connected via USB and there is power applied to the camera ... once connected, look at the camera LCD screen and select "Computer" for the connection ... then, in Final Cut Express, select Log and Transfer (File menu), and you will get a new window. You camera should be recognized and you can select the video takes that you want to transfer and then hit "add selection to queue" and the transfer will begin.
You will first want to check in Final Cut Express where the transfers will end up on the computer, and pick a suitable location with plenty of hard drive space (Final Cut Express menu / System Settings / Scratch Disks) so you can find them if you want to at some point in the future.
Assuming you will be editing in Final Cut Express, you won't actually need to find them, but its important to select a scratch disk location that has plenty of hard drive space, and if you want to copy one of the clips to use it directly to just upload to YouTube or something like that, you'll know where they are (they will be .mov files, and can play all by themselves using Quicktime or any similar program)
As always, refer to the manual if you run into any problems ...
Hope this helps!
See our latest DVD at www.whamuniversal.com
tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP...
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
tip
FCE to FLV/SWF converter, embed FCE project in webpage
One friend of mine is using Final Cut Express to edit your film footage and the final film will be uploaded to your website for viewing. He need to get the videos to FLV format for easily web viewing. Unfortunately, FCE doesn't export to FLV. Do you have this problem with my friends?
My advice is to use FCE to Flash converter. The FCE to FLV converter can meet your need to convert FCE exported movie to FLV/SWF and generate a HTML web page embedded with flash player so that you can easily upload movie exported from Final Cut Express to Youtube and insert your masterpiece created in FCE to your website.
Step1. Export Video from Final Cut Express
Export video from Final Cut Express. And the exported video is in the MOV format.
Step2. Launch the FCE to Flash converter
After download the FCE to Flash converter, double click its item to launch it. The interface is user-friendly, look like this:
Step3.add MOV files exported from FCE
Press "Add Video" button on the top of the interface and browse the pop-up directory, choose all mov files exported from FCE to import into the converter.
Step4. Add effect
Hit the "Effect" tab. Select a cool special effect for you flash.
Step5. Start FCE to Flash conversion
You just need to click the "Start" button and the FCE to Flash conversion will start automatically.
Knowledge on Final Cut Express
Final Cut Express(FCE) is a powerful and extensible video editing software designed by Apple Inc. The supported video formats by FCE is DV, HDV and AVCHD. The special feature is its ability to import iMovie 08 projects and use iMovie as a video library. Among three distinct tiers of video-editing software Apple offered (iMovie, FCE, FCP), iMovie catered to beginners, Final Cut Express mid-level video editing fans and Final Cut Pro pro-level editing people.
Next: How to convert videos to Flash, SWF, FLV on mac with video to Flash/FLV/SWF converter for mac.
on Jun 22, 2010 • Computers & Internet
3helpful
How to download canon hf20 movies and change them so can alter the movie
Hope this helps!
3helpful
How do i transfer canon hf20 files to iMac with usb cable? Only the Digital Video Solution Disk has "for Macintosh" on it. All the File Transfer disks say windows and will not load on my iMac
You need an editing program, and then you will transfer the files from within the program ...
Hope this helps!
See our latest DVD on PA systems, avoiding feedback and echo, and great AA Conference Speaker Tapes and CDs at www.whamuniversal.com
2answers
Not able to down load video from my Panasonic videto Mac Pro 3.1
Basically mac does not like USB, it is bad and uses burst of information not suitable to video so FCP kinda ignores the option. It works ok for the transfer of non-realtime info. Can you not use DV to FW. Loads of people are having this issue as MAC have dropped it with the new MacBook to in my opinion force people to buy MBP.
2answers
Final Cut Express 2 won't Panasonic PV-GS320 minidv camcorder
hi,because final cut express only support .dv,mpeg-4 and .mov formats.
so you can convert your video files to .mp4.
you can use the third party software convert your video files to .mp4 format.
you can use Mod to Final Cut Express Converter.
http://www.fceconverter.com/mod-to-final-cut-express/
2answers
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
3answers
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
