Question about HP Jornada 928
Battery/power problem bought 1 of the first jornada 928 models, it lasts on battery for approx 1 hour only. i have tried replacement batteries but the jornada does not recognise the replacement battery and will not power up. does anybody know why this is happening?
  • 15 Answers
SOURCE: No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Posted on Mar 01, 2008
0 characters
1 Points
My blackjack will not turn on
Please try to power cycle your Samsung BlackJack. Please remove the backlid and remove the battery. Now plug in the charger and after that the battery. Now leave this phone for approx 1 hour. Now try to turn it on.
I hope this helps but if does not even help you need to contact Samsung for a repair.
Please do rate my solution.
Regards, Rashid.
Oct 28, 2009 | Samsung BlackJack II Smartphone
Jornada 720 touchscreen calibration doesn't last
I had the same problem, and i fixed, it's not totally true, the inners electronics components suffer damage with time, i think the hings and flex suffer needs to be cleaned with time, I follow the instructions at http://www.hpcfactor.com/support/cesd/h/0046.asp with to much care, an voila no more recallibrations needed,
Feb 27, 2009 | HP Jornada 720 Pocket PC
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
Blank Screen on Jornada 680e
need new screen ok get one off ebay
Jan 30, 2008 | HP Jornada 680e Pocket PC
Audio Click
This could indeed be the amplifier section powering down to help conserve the battery.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Jornada 680 "booting cold"
Sounds like a loose connector inside, I had a similar problem after I took my 680 apart to replace a cracked screen. It took a few more dismantlings and re-assemblings until it settled down. You should also check the state of the button cell battery.
Sep 12, 2005 | HP Jornada 680 Pocket PC
Series - Syn Error
The clock on either your Jornada or the desktop PC is set wrong. Either one of them is in the wrong time zone, or more likely, one of them is not set to compensate for daylight savings time. Good luck,
Internet explorer error
Do you have problems also with downloading your e-mails? If not, you have problems with DNS - your computer cannot recognize web page name and convert it into proper IP number. Try to contact with your ISP and gain these numbers, which you have to enter into proper place in Connection menu (Advanced options)
Sep 12, 2005 | HP Jornada 928
Water damage
It is probably permanently damaged now. In general with electronic devices if you get them really-really dry before turning them on then a little clean water doesn't hurt. These never really turn completely off though so just getting them wet might be the end.
Clock out of control
I have a Jornada 568 but I've never seen the behaviour you describe. Is it possible that you damaged or caught a small part when you installed the new battery? Your new battery, was that the small round battery or a battery pack on the back of the unit. "Resetting to Factory defaults" suggests that there is no power at all, doesn't it? If the small round watch battery is dead then that might effect the clock.
Sep 12, 2005 | HP Jornada 568 Pocket PC
HP Jornada 928 Logo
23 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
