Question about Hitachi 200GB External USB 2.0 Hard Drive
My hitachi makes a clicking sound
I dropped my media player/ext hd earlier.
been making a clicking sound since.
wont work on tv and wont show up on
pc now either. just makes a constant clicking sound.
i fear the worst.
is there any possible way of salvaging the lost data?
thanks
  • liam staunton Sep 01, 2008
    i believe its quite expensive getting an expert to secure the recovery of the data so i guess ill have to live without it.
    the warranty was up last month sadly
  • 796 Answers
I'm afraid if you would have damaged the cylinders inside...
if yours hd is under warranty you can try it with a computer repairman...else if would cost you more of the secure recovery of the data in the hd..
thankyou
Posted on Sep 01, 2008
Nextar MA933A MP3 Player says empty disk
Hi, When you transferr music from your PC use windows media player. It work well with these players. Make sure usb cable is securely attached. May not work well with Mac.
In Media player click on Sync tab and drag and drop files in sync list on right. Good luck
Jan 13, 2014 | Nextar MA933A MP3 Player
Connected PC to LG with HDMI. Wonderful pic but NO sound. PC HDMI audio test works great and sound is clear thru TV. When movie is played from PC to TV there is no sound.
How do you get HDMI out to tv, through a graphics card? Is Is it HDMI direct out of the card or DVI adaptor? I believe you will get a ping even if the volume is turned down and when playing a movie you would have volume control throuh the DVD player, the computer and the tv. Make sure your volume is turned up on dvd player and right click on your speaker icon in taskbar, at lower right of screen and make sure that volume is up. When you do the ping are you checking a "HD" audio driver. Look in 'device manager" in "sound audio and game controllers" and right click on "HD" devices and make sure they are enabled. Let me know what happens. When you look at devices in device manager you also may see a warning. If so click on the symbol, ? ,!, or triangle and follow proceedure.
Dave
Apr 06, 2011 | LG 42LC2D 42 in. LCD HDTV
My external hard drive is not being seen by my computer?
1 of 2 things can be wrong...1 (cable may be loose) unplug the cable (ext HD) connected to pc, now reinsert back into pc..try this once or twice...until you see it appear in my computer....if this is not working and your ext HD came with a CD software..uninstall (make sure ext HD is not connected) software, then reinstall make sure your firewall allows it to be connected....this should do the trick...now plug HD back up to pc...do not format your ext hd unless you really really dont want the data on it (format erases everything)
May 27, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi ultrascan hd- no picture, just makes clicking sound
wires are crossed over to wrong amplifiers when hooked up you might have blown completly
Dec 06, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Aug 09, 2008 | Televison & Video
I have an Archos 605, and have also purchased the console to connect it to my tv. This console has a USB connection, and the instructions say that I can connect my external HDD to it, and view this using...
Here's what you do.
Make sure that you can play one of the sample videos to your TV. Next, stop and go to the home screen.
Next, if your external HD has a powersource, plug that into the wall and the device so that it has power. Next plug the usb cable into the side of the DVR Station. The device screen (or the tv if you are still on tv out) should say, external device connecting. It will show the double browser screen and then just go to the file desired and click on OK. If the device doesnt recgnize and mount the external hd, could be because there is not enough power to the ext. HD or the HD is formatted in somehting other than fat32.
May 09, 2008 | Archos Audio Players & Recorders
My media player 11 won't show up on my computer? it was working fine but now it wont show up
Read the warning about this device and Windows Media Player 11 at www.usasupport.philips.com
You will need to reformat the GoGear in Windows Media Player, but do a firmware upgrade first - open the Philips Device Manager and click on the Update tab. Then click the update button. After the firmware upgrade is done, open windows Media Player.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your GoGear to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Philips Go Gear SAXXX" (wording may vary slightly), and then select "Format." - this should erase everything, and make your player properly read in Windows Media Player.
-Tha Mp3 Doctor
Mar 21, 2008 | Philips GoGear HDD1830 MP3 Player
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Hitachi 200GB External USB 2.0 Hard Drive Logo
155 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
