Question about Dream Vision DL 500 StarLight Multimedia Projector
Unit will not turn on
My unit will not turn on either manually, or with remote. Any suggestions
  • 3,051 Answers
Hello there:
this unit has a internal fuse that has probably blown and is in need of replacement if this doesent cure the problem i would contact the manufacturer of this unit for further repair suggestions. ok?
best regards michael
Posted on Sep 24, 2009
I have a Mitsubishi air conditioner model SRK50ZDA-S. The remote display seems to be working fine as I can change all of the settings as normal, but the wall unit doesn't respond to it. I can turn the wall...
The remote batteries could be defective or installed incorrectly. Try removing the batteries, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries and testing operation. If no operation, the remote may have failed or there could be failure at the wall unit.
Jan 07, 2015 | Mitsubishi Heating & Cooling
I get set 3 when i press the remote and nothing else no matter what i press play etc any suggestions
Try reprogramming the remote so it matches the unit. If you get SET 3 or DVD 3 on the display, chances are the remote's command code is different to the unit, in which case the following may help a bit:
Ensuring new batteries are in the remote, correctly polarised ( + and - ) and with the remote pointed at the unit (while unit is on), press and hold both the [3] and [ENTER/OK] buttons TOGETHER for 5 - 10 seconds, then release. The remote should now fully control the unit.
If it doesn't, check the batteries and repeat the above. The above procedure is a suggestion based on Panasonic DVD recorders and their operation troubleshooting manuals. Give it a try at least.
Aug 14, 2011 | Panasonic DMPBD45 BluRay Player
B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next...
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Jun 01, 2010 | Heating & Cooling
Home Audio problem
Have you looked in the manual for TROUBLESHOOTING: No Power?
It suggests unplugging the unit for a short time, then plug it back in, then check for a blown fuse, then take it to the ER.
Mar 16, 2010 | Audio Players & Recorders
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Sep 04, 2009 | Crosley CR247 Shelf System
Our DVR jumps to the suggestions screen and we can't get back to the programs we've recorded unless we unplug the unit and let it reboot.
mwe71704 -
I saw a similar problem with a vcr and it's menu years ago. It turned out to be the remote. If you can operate the unit without using the remote, try that to see if the problem happens again. If not, the remote is the issue. You don't say if there were any factors that could be traced directly to the remote (like the jump happened when you pointed the remote at the unit or pressed a button). You might also have a button that is stuck.
You'll have to do some experimenting to see if the remote is the cause, but it might be worth it. If the unit can't be operated without the remote, reboot it with the remote pointing away from it. Then turn the remote towards the unit. then try some of the functions. If it jumps to the suggestion screen, note which button you had just pressed and repeat the entire process. If a particular button always causes the issue, that's the culprit. You may want to just use the unit as you have been, rebooting as necessary, but pay attention to what happens right before the jump to the suggestion screen.
Thanks,
videoman7
Aug 07, 2009 | Directv (R10) DTV Receiver / 70-Hours...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
there's no signal comes to you tv that why the screen is blue, the problem of your tv is the tuner, so check the the requirment of the tuner to determen if its good or not.
Sep 17, 2008 | Philips Magnavox 27MS343S 27" TV
Turns on 1 out of 4 times?
The problem might not be with the amp. You will need to check the "remote" output from your head unit at the amp end using a voltmeter. It should be ~12.5 volts dc when the head unit is turned on. If there is no voltage when the head unit is turned on, then the problem is not the amp. The head unit may be bad or there may be an intermitant short somewhere in the remote wire.
You can test the amp by removing the remote wire and connecting the remote input directly to the +12v terminal. Use a short scrap of wire. This will (should) manually turn on the amp. Don't forget to return the remote wire to the remote input or the amp will never turn off.
A friend of mine had his remote wire shorted to ground once after he replaced his head unit. Turns out when he slid the new one into the dash opening he pinched the remote wire against the chassis. Frustrating but an easy fix.
Sep 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Dream Vision DL 500 StarLight Multimedia Projector Logo
83 people viewed this question
Top Dream Vision Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dream Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
