Question about Whirlpool AD70USS Dehumidifier
Dehumidifier Humidifier is tripping the circut breaker when it is plugged in. I have taken the housing apart and disconnected the compressor but it is still tripping the circut breaker.
  • 462 Answers
See if you have a grounded circut in the appliance. Check 1 flat to your volt ohm meter. Connect the other probe from meter to the other flat. And you should get a reading of resistance. Next connect 1 probe to the flat then the other to ground. A reading - indicates nothing until the next step. Now try the other flat to the ground?
1 Of these flats are connected to the nutural and possible feed through or back to ground in the appliance. The other one though should not read to ground. If you get a ground reading on both flat of the plug in someting is together that should not be.
If you dont get a readign try plugging in at a different outlet. A circut that has too much load will cause circut breakes to over heat and trip.
If it runs at a different outlet make sure its on a different breaker. If its on the same breaker it will probably start acting up again.
DOes this help? If so please rate me as high as possible If not please restate your problem to help me understand it better. Thnaks for using Fixya and Good Luck.
Posted on Mar 24, 2009
  • Farley Redfield
    Farley Redfield Mar 24, 2009
    Almost forgot The wall plug could also be at fault. But this can be eliminated when using a different circuit. then by plugging in a different appliance like a hair drier. However, it would (if overloaded) trip out the breaker also.
3 Suggested Answers
  • 625 Answers
SOURCE: Dehumidifier tripping the breaker
be very careful - with the unit unplugged - try shorting the capacitor with an insulated screwdriver. if you get a healthy spark - the cap is probably ok. if you don't replace the cap. the cap is used in the motor's start winding.
Posted on Aug 21, 2007
SOURCE: trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Posted on Apr 27, 2008
When I plug it in and turn it on it trips the breaker. I have tried other outlets but it does the same thing.
Hi, The compressor is locked up and is bad... that is what trips the breaker...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
Jul 31, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference.
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
Circuit breaker trips when unit is plugged in
you have a dead short in the compressor.........SORRY
May 20, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
Goldstar dehumidifier keeps tripping the circuit breaker in the house
your problem may be within your dehumidifier or it may be within the circuit breaker itself. I just replaced a faulty breaker this morning for a customer.
plug the dehumidifier into another plug which you are sure is working and also sure is not on the circuit you have been using. [turn that breaker off and you will know what it controls
if the problem is the breaker, replace it. if the problem is the dehumidifier look for a poor connection, a bare wire touching the frame of the dehumidifier, a fryed wire, etc. good luck.
Sep 09, 2009 | Dehumidifiers
Dehumidifier trips breaker
compressor problem. Talked with coworker who had the same problem. He brought his in for repair and was told the compressor needed to be replaced. The cost of compressor close to the cost of a new unit so time for a new one.
Mar 25, 2009 | Haier Dehumidifiers
Aug 21, 2007 | Maytag M7DH45B2A Dehumidifier
Ground fault as soon as I plug it in.
You more than likely have a dead short in the compressor
Nov 15, 2006 | Maytag M7DH65B2A Dehumidifier
Whirlpool AD70USS Dehumidifier Logo
223 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
