Question about Sony Cyber-shot DSC-W55 Digital Camera
Zoom problem When we go to zoom or "un-zoom" the lens clicks and doesn't focus. Sometimes we get "turn off and then back on"
  • 74 Answers
Turn on then gently take hold of the end of the lense and genlty twist and pull you may hear a click. then turn off and on again this may solve your problem
Posted on Nov 03, 2008
My lens will not focus. Pictures are all coming out blurry no matter what setting I have the camera on, and no matter how much I zoom in or nout.
Hi
You know sometimes the lens will not focus if you have a physical damage etc., first of all i would like to clarify some points.
1. Did you place your camera near to a strong magnetic area?
2. Did you drop the camera?
3. Did you use Zoom in Zoom-out continuously at the same time?
for the first point i am sure it was exposed to strong Magnetic field, as and when it is exposed the coil of the zoom lens which move the lens in and out will get out of place and makes it impossible to maintain focus. If so then better is to open the camera and re-adjust the lens. But if you are confident to put it back then open it or try to slowly wiggle the camera and check if it gets better.
Jul 18, 2011 | Kodak EasyShare Z915 Digital Camera
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
My Nikkor 70-300mm lens will not zoom
First thing: Don't try to zoom it at all anymore. The mechanism inside is broken or somehow disconnected, and you can make it worse by trying. Please take it in for repairs as a camera pro will need to look at it.
Mar 19, 2009 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Problem with focusing
sounds as though the focus motor worm gear is binding up. I have ,at times been able to take this assebly off the zoom lens ,oil it and reinstall it. very very light amout of floil, a very thin oil. Also the zoom motors worm gear binding will cause this problem, sometimes one of these motor/worm gear assemblies will have to be replaced.
Sep 15, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
