Question about Hamilton Beach 25300 Meal Maker Express Indoor Grill
Drip Tray I need a drip tray for a Hamilton Beach 25300 Grill
  • kdermac1 Dec 01, 2008
    I also need one Thank U
  • fubu_37 Mar 17, 2009
    i need a drip tray as well,thanks
5 Suggested Answers
  • 72 Answers
SOURCE: Replacement drip tray and spatula
Customer service at 1-866-372-5866 should be able to help you!
Posted on Oct 23, 2007
bbtoast
  • 319 Answers
SOURCE: DRIP TRAY
Please try these numbers or website, hopefully they can help!
CUSTOMER SERVICE NUMBERS
In the U.S. 1-800-851-8900
In Canada 1-800-267-2826
Web site address: www.hamiltonbeach.com or
www.proctorsilex.com
Posted on Jan 10, 2008
SOURCE: George Foreman Grill - Model # GRP4P
Make a drip tray out of alum. foil. Throw it out when you're done.
Posted on Feb 07, 2008
KMusselmann
  • 247 Answers
SOURCE: where can I get a drip tray for my george foreman grill
Here is a place that sells parts
Pls rate the answer
Kurt
http://www.appliancefactoryparts.com/gasgrillparts/brands/george-foreman/grp4p.html
Posted on Apr 13, 2009
SOURCE: need a instruction manual for Hamilton Beach
if anyone knows where i can get a manual can you plwase let me know thank you very much
Michele ragamuffin59@yahoo.com
Posted on Jul 16, 2009
Need replacement drip tray liners for Thane Q Grill
I have several boxes of replacement foil trays for the Thane Q Grill. email gary@firstchoicemusic.com
Sep 23, 2012 | Thane Q-BBQ Grill
Missing manual for hamilton beach grill model 25300
The Use and Care Guide for the Hamilton Beach 25300 Meal Maker Express can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840156900.pdf
Jun 30, 2011 | Hamilton Beach Kitchen Appliances - Others
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
Viking Grill
Remove the drip tray, the serial# tag is on the unit beneath the drip tray
Jan 04, 2009 | Viking VGIQ5323RE1N Gas Grill
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
How does drip tray for cooktop fit above grill should it touch the element? it is a chef supreme upright approx 2000 year
the drip tray should not touch the element all. it will cause a problem when you run the self-clean. sounds like the cover is too big.
Sep 12, 2008 | Kitchen Ranges
Jan 24, 2008 | George Foreman GRP4P Indoor Grill
DRIP TRAY
Jan 10, 2008 | Hamilton Beach 25265 Indoor Grill
Sep 05, 2007 | George Foreman GR15 Indoor Grill
Hamilton Beach 25300 Meal Maker Express Indoor Grill Logo
126 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Custom Exchange
Custom Exchange
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
