Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Downloading cd unit came with ink at purchase,then bought extra ink at that time. at set up NO BLACK.Had to run out and buy.Baloney! Now ink is not vivd upon calibration. Downloading CD I get application error when wanting to open program Would like to get info from program.No direction book came with printer. Software could be user error.Don't know Please Help.Thank You
  • 21 Answers
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or As for the software issue I would try running the clear utilty program from and the try redownloading the software from the above link go/download
Posted on Sep 03, 2008
Having problems with my ink cartridges, now I've used compatible cartridges as advised.
You may have gotten a cartridge that was in the store for a long time. Some cartridges may get solidified ink in the nozzles. Try a new cartridge from another dealer.
Oct 04, 2014 | Epson Artisan 710 AllInOne InkJet Printer
Upgrade your printer and continue to refill your own ink cartridges
I just had my HP 8600 document feeder fail. This problem part cannot be ordered for replacement, and to have it repaired will cost almost $200. Well a brand new one on sale is only $250. And better yet, upgrade to the HP Officejet Pro 8630, since HP will no longer be manufacturing the 8600.
I have saved hundreds of dollars, refilling my own cartridges. I upgraded, after I learned that the newer model uses the exact same ink cartridges. So, I am on my third HP Printer, and I have purchased only one set of cartridges in 3 years. I have refilled my color cartridges at least 8 times. They need refilling more frequently than the black. (The black ink cartridge is twice the size.)
In addition, I purchased a three year extended warranty for $20 or $30. If anything happens to this printer in that time, it will be replaced automatically, and I will not have to pay for shipping.
In essence, I am in position to have used the same set of ink cartridges for 6 years. I only put my new cartridges in after I have refilled the empties. After the printer resets, I pull them out and put in the refills. So you see, my printer came with a set of cartridges, and I purchased one extra set, for resetting the printer after refilling the cartridges.
I suggest to really control your costs, consider buying a quality printer, that will be good for years of service, add a service contract, and refill your own cartridges. If you print as much as I do, you are realize a significant savings in the cost of ink.
I know that I have saved a minimum of $360. Add the cost of inconvenience and going to Walmart for refills, and you may be realizing a savings of $150 per year, just for refills.
Good luck, and plan ahead.
on Mar 04, 2015 | HP Officejet Pro 8600
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Ink replacement issue!!
have you bought genuine ink??? well if your answer is both yes or no, you can always opt to have it replaced from where you bought it, but please try to buy genuine inks, so as you will have no problems regarding ink cartridges.
Jun 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I cannot print black when the color cartridges are empty. MOdel mfc665cw
Don't you see the logic? Brother wants you to spend money by buying color cartridges. And also, most printers are also using colors to make the prints darker.
Jan 09, 2010 | Brother Office Equipment & Supplies
I have purchased compatible ink cartridges for the first time and the only colours that print are yellow and black
Sometimes the compatible carts don't fit right, the inkpad on the bottom is too far up in the cart. You need to buy extras and try swapping them out before going for more expensive repairs. Do a couple cleaning cycles each time you try new carts.
Jul 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
I purchased a BJC-85 color bubble jet printer in 2002. I have lost my disc to set up printer; I just received a new labtop for work and I dont want to buy another printer. Is there anyway you can take my...
The drivers that were on the CD probably won't work on your new laptop anyway. You can download the latest drivers here (use the box to select your Operating System -- Windows XP, etc.).
You can purchase ink online here. The BC-10 is a black ink only cartridge, and the BCI-10 is the replacement ink tank. The BC-11 is a cartridge with both black and color ink, and the replacement ink tanks are the BCI-11bk and BCI-11clr.
Jul 26, 2008 | Canon Office Equipment & Supplies
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
