Question about Kenwood KDC-2011S CD Player
I wanna hook an ..
Legacy Amplifer and Jensen 12inch Subwoofer Enclosure (goes in the trunk) I was wondering if these were capatiable with this Cd Player??
  • charlescomer Sep 01, 2008
    Okay.. do you know how to wire an Amp??
  • 81 Answers
Yes. Just run your RCA leads to the amp (after properly wiring it). You can use either the front of rear pre-out connections. If your amp has a built in crossover, Use the low-pass filter setting at around 60Hz.
A copy of the owner's manual can be found here if you need it:
Hope this helps!
Posted on Sep 01, 2008
What is the watts
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
What size should i make the enlcloser
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed. You will need approx 2 cu ft
To tune this 2 cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome
Dec 02, 2010 | Jensen XS-1010 Car Subwoofer
How do i wire up my amplifer into my car
cable to battery, cable to ground(in the trunk somewhere. rca cables and remote wire from the back of the car stereo.
Aug 04, 2010 | Legacy 2CH 1000W AMP Car Audio Amplifier
Speaker removal
Good day,
In your trunk there are 2 small amps. The first amp is connected to your car speakers. The second amp is connected to your subwoofer. Once you locate the subwoofer amp. Your subwoofer amp will be the amp close to the sub enclosure. Unplug the subwoofer from the amp. Your next step is to unscrew the 4 10mm bolts so that you can remove the sub enclosure. At this point you can now remove the enclosure. It will take a some time as it always seems to be up there pretty good. But once it starts to move it should come out with little work. I hope this helps with your removal of the subwoofer.
Mar 08, 2010 | 1995 Lincoln Town Car
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Oct 03, 2009 | Pioneer DEH-P690UB CD Player
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
Sub Amp and jensen headunit
yes a rca y cable will do the trick thats what the guys down at video kingdom told me for my vm9410 with single sub out
Mar 05, 2009 | Jensen VM9510 Car DVD Player
Specs for box
Download the manual for the woofer from the Sony site. It will give you the volume needed for the sub.
If you need help constructing the enclosure, there are several applets on the following page:
Click HERE.
Jul 19, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sound problem
sounds like you have the antenna wire connected to the power amplifer lead in the car.
Go behind the radio, there is a solid blue wire that will be connected to a wire in the car, take the solid blue wire off, and connect the blue/white from the radio to where the solid blue was originally connected. This should solve your problem
Nov 24, 2007 | Jensen VM9410 Car DVD Player
Kenwood KDC-2011S CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
