Question about X2Gen MG19MY 19" LCD Monitor
Color Resolution My monitor color resolution wont turn back into its default color. Instead its all purple and blurry. i try to do " auto color " but it's same . what am i going to do? please advice. Thanks
    Scholar:
  • 188 Answers
Sounds like a piture tube or internal video driver in your monitor. You probably lost the green channel. If the monitor is dated I would replace it.
Posted on Sep 20, 2008
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
Color problem
LCD Screen problem if your LCD in under warrnaty so in that case LG provide Free services and they change your LCD Screen please contect LG Services station.
May 11, 2010 | LG 22" FLATRON LCD Monitor
How do i determine the maximum resolution an Acer Aspire 4732z can take? i know the thing wont show the right result cause i've hooked on two different monitors to this laptop before and i got different...
The monitor needs to be identified for the resolution to be known to the system, otherwise default limits will apply.
For some monitors 'drivers' are available that provide that info together with a color profile.
But best check the specifications of the monitor in the manual of on the web (based on model #).
If you use too high a resolution of refresh rate you can really harm the monitor...
Apr 23, 2010 | Computers & Internet
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Weird colors!
Normally this happens if the plug at the back of of the monitor or the computer loose. Try to secure that cable. If they are secure, check the pins on the ports at back of the monitor / desktop or the cable. I also suggest that you try a different monitor cable.
Jun 17, 2009 | LG 22" FLATRON LCD Monitor
Nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
Jan 25, 2009 | Dell Dimension 4600 PC Desktop
17 crt monitor (BOKA)turned to green resolution
Try moving the VGA cord to the PC, faulty VGA cord displays such color problem.
Nov 27, 2008 | Computers & Internet
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
X2Gen MG19MY 19" LCD Monitor Logo
74 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
