Question about Sony Cyber-Shot DSC-F828 Digital Camera
PROBLEM: F828 & external flash
I have an external flash that fires when it detects another flash nearby (i think it has that photo detector trigger). I have a setup in such a way that my external flash will fire the moment it detects the flash of the cybershot fired. I have noticed that my images are under exposed no matter how much i adjust the F-Stop and the power of my external flash. The camera seem to be doing something automatically without my knowledge. pls help. thanks!
    Master:
  • 551 Answers
Turn off the Red-Eye Reduction in the set-up mode. This may very well cure, or at least help, your problem. Let us know what happens.
Posted on Sep 12, 2005
    Master:
  • 551 Answers
I think this is due to the TLL preflash of the 828 internal flash. Each time it actually fires 2 flashes. First one for metering and second one for actual exposure. First "fake" flash probably trigers your external flash which is too early. Slution... hmm i think there are afordable slave adapters out there which detect the TTL preflash, ignore it and fire the external flash on the right timing along with the main flash. cost.. about few tens $ i think. they can detect also infrared light so you can mount IR filter on your internal flash to prevent interfering with the exposure...
What is the hobby of metal detecting called?
A metal detector is an electronic instrument which detects the presence of metal nearby. Metal detectors are useful for finding metal inclusions hidden within objects, or metal objects buried underground. They often consist of a handheld unit with a sensor probe which can be swept over the ground or other objects. https://detectorly.com/complete-guide-metal-detecting
Mar 18, 2018 | The Toys
How deep do most metal detectors go?
If you are looking for gold or other precious metals that are buried deeper than one meter, you need a 2-box metal detector. Unlike traditional coin detectors, which are made to find smaller individual items, a ground two-box metal detector can penetrate the earth using special search coils that transmit signals. https://detectorly.com/key-things-consider-purchasing-metal-detector-beach
Mar 15, 2018 | Retail Supplies
What is a good metal detector?
A metal detector is an electronic device which detects the presence of metal nearby. Metal detectors are useful for hunting metal inclusions hidden within objects, or metal objects buried underground.This is the depth to which your metal detector is able to search for coins and other objects. A good metal detector has a sensivity that is the ability to detect metal objects from a distance. Lower frequency detectors offer better depth.You can usually find coins to a depth of one and a half times the search coil diameter. https://detectorly.com/ever-wanted-know-metal-detectors
Dec 16, 2017 | Retail Supplies
Voltage Detector Question
I don't believe so, as you are detecting the electrical field and not the current. Most switches will arc when switched, but a small flash you can see in the dark is normal.
Jan 03, 2015 | Cars & Trucks
My Marantz BD8002 (year 2008) after a while automatically turns off. Sometimes plays for hours and sometimes only a few minutes. Any idea what the reason for such behavior? I would appreciate for any...
I have a blu-ray player that was acting strangely - turning off unexpectedly - I finally noticed that it happened often when fire trucks were nearby - and tracked down two the lights triggering the IR remote detector.
May 25, 2014 | Televison & Video
Flash does not fire
Does flash pop up? Does the little electronic flash symbol appear in the LCD when it charges? Really not enough info in your post.
A few thoughts:
If the flash will not pop up check the external flash detection pin in the hot shoe (located on one side under the spring, which can be popped off with a knife blade or similar). If this is stuck down the flash will not pop up because the camera thinks there is an external flash in the hot shoe.
If the flash pops up and you get an 05 error or it makes a clicking noise and you get an 05 error this usually means sticky liquid spillage around the flash. It needs to be disassembled and cleaned and the pivots lubed. Squirting WD40 on the flash WILL NOT SOLVE THIS PROBLEM. NEVER SQUIRT WD40 IN ANY CAMERA!!!!!
It the flash pops up, and the little electronic flash symbol comes on, but goes out when you push the release button it usually means the flash board is bad.
If the camera has been impacted, then either the flash tube is cracked/broken or one of the wires that goes to it or the trigger coil may be broken inside
Mar 11, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
What does VG2 mean
It is a radar detector detector. So if you are running a radar in a state where it is illegal, this technology can detect the presence of your radar detector and you can be pulled over and ticketed. This is done by detecting the local oscillators and other "RF leakage" from the radar detector.
Sometimes you may notice that when you are near another car with a radar detector, your radar detector may go off. There are situations where your own radar detector can detect leaking RF energy from another detector in a nearby car.
Sep 09, 2009 | XRS 9330 Radar Detector
My camera is a Canon 400D. I put an external flash on it just few moments ago (canon speedlite 580EXII) and the flash wouldn't go off when i took pictures. So i took the flash off, but now the flash on the...
Hi Chrissy, I had observed the same problem - after an external flash had been removed from the camera, internal flash didn't pop up. Tried to look at the Google and finally found the solution. It helped me and could help you as well:
The usual reason is that the camera thinks that there's an external flash mounted on the hot shoe. Check the external flash detect switch. It's located under the right side of the shoe (there is a metalic piece which is kind of "elastic". Just try to push it and release several times, may be put the screwdriver softly under it and out... It helped me. Here is the picture of location of the detector.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Sony DSC-F828 Faulty Flash
Try resetting the camera. It is next to the battery release. I had a similar issue and posted help. No remedey. So, after praying about this issue, I was lead to power it down and eliminate all the power by taking out the battery push the power button and many others. I found the reset button pushed it and it is all working now. The praying for a solution was key. Praise Jesus. DRD
Aug 08, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
