Question about Pioneer DEH-P4800MP CD Player
No sound i just bought new speakers for my car and i still dont get any sound out of them. I even ran my own speaker wire and set them to match up
  • 81 Answers
Either you have a wiring issue or defective speakers. If you have a multimeter, set it for an ohms reading. With the speakers disconnected, ohm the terminals. It should read very close to the ohm rating of the speaker (as indicated in the specs).
You may also check the fade control on the deck to make sure it's balanced between front and rear.
Hope this helps!
Posted on Sep 01, 2008
Speaker wiring diagram for a 08 dodge 2500 truck with 7 speaker infinity
Never have found good wiring diagrams for stereo's. Bought them and color codes didn't match. I have mitchell and alldata at work, they don't match. I wire them in with a volt/ohm meter. I find B+, Then hook ignition the the heater control wire. Ohm out the speakers. Thing is, you have infinity. You'll have to find the amp and cut the speaker wires and patch them there also, first. Just a note.. All speaker wires are twisted/paired wires. Cut the tape back 4 to 6 inches to find them. Another note. The speaker wires from the stereo to the amp will be a set of colors. From the amp to the speakers will be different colors.
Nov 01, 2016 | Dodge Cars & Trucks
I have a panasonic 803us 8-track player. Bought new speakers for the unit, but none of jacks match up. I would like to adapted the new speakers before buying another set of speakers. Can anybody help me...
Why not leave the original jacks in place, cut the wires near the old speakers and new speakers and just replace the speakers, using 2 scotch lock connectors to connect the 2 wires to each speaker. (Keep polarity consistent for each speaker). Of course you should test one speaker first to make sure they will work with your unit, before you cut any of the remaining wires.You can always connect the originals back as long as there is a bit of slack in the wire.
Jun 24, 2014 | Audio Players & Recorders
I bought a metra wiring harness for my 93 mustang to put in an aftermarket stereo..stereo powers up but can not get sound to speakers..i triple checked all wires i spliced..all colors match..any...
Don't know the model. Be aware that Ford is whimsical when it comes to color codes and even varies from model to model. Whichever pair the adapter uses for the left door speaker, connect the + wire to the ORG/LT GRN wire and the - wire to the LT BLU/WHT wire. For the right door speaker, connect the + wire to the WHT/LT GRN wire and the - wire to the DK GRN/ORG wire. For the left rear speaker, connect the + wire to the PINK/LT GRN wire and the - wire to the PNK/LT BLU or TA/YEL wire (same wire). For the right rear speaker, connect the + wire to the PINK/LT BLU wire and the - wire to the DK GRN/ORG or BRN/PNK wire (same wire). REMEMBER, the colors of the Metra adapter may not match what's in your car
Sep 27, 2012 | Car Audio & Video
I dont kno the wiring colors for my 2000 taurus radio
All you need to do is get the power, ground, and antenna hooked up then start with two colors matching, example: one purple and one black with purple line hook those up to a matching speaker wire then turn stereo on and go to balance setting choose back left if speaker does not sound then go back right and if speaker does not sound then try front speaker right and then left once you find correct speaker move on to next two matching remember to. Mark wires FL or fr or bl or back right. Good luck
Sep 10, 2011 | 2000 Ford Taurus
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
I have an onkyo tx-8255 receiver and i bought a psw-505 polk audio subwoofer to supplement my Boston acoustics cs-26 bookshelf speakers but i cannot get more than the deepest of bass to emit from the sub. ...
The problem is you are dealing with two different brands of speakers, I know because I ran into the same issues you are facing now, I had a Bose sub matched up with two Radio Shack Satellites and sound was not balanced it was awful. Finally I broke down and bought a pair of Bose Satellites and I have never regretted it since. The point I'am making is that when you mix brands the sound will be unpredictable, the problem with most subs is they have a very low roll off frequency even without the crossover making almost impossible to match speakers.
Feb 05, 2011 | Onkyo TX-8255 2 Channels Receiver
No sound from speakers
Check the audio settings in your Kenwood consult the manual.
May 08, 2009 | Car Audio & Video
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Pioneer DEH-P4800MP CD Player Logo
48 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
