My AUDIOSONIC 68cm TV, model: KM2926 has a problem. It appears to be 'zoomed in' or have an amplified view. for some reason it crops out either side by a few cm which is realy annoying while watching movies or playing video games. I have the remote aswell. I cant seem to fix things, any help is appreciated (:
SOURCE: Remote died while tv was on Video 2
To fix that problem on the Toshiba 32AF41 just follow these instructions. On the front of the TV there are seven buttons. One of the them is labeled "TV/VIDEO". Just press it until it switches from "VIDEO 2" to "TV". That simple.
Posted on Feb 18, 2007
SOURCE: lost remote
lost remote, can not switch imput
Posted on May 02, 2008
SOURCE: Loss of Picture on Right and left side
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
gbr@yahoo.com
Posted on Dec 29, 2008
SOURCE: Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Posted on Feb 16, 2009
SOURCE: how can we set sylvania tv to game mode from the front panel?
hit menu and then hit the up volume button once and thn you should have it by the way i cant play games on mine how r you playing games on yours?
Posted on Feb 22, 2009
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
Once u zoom into the picture that is very far away how do u keep the picture zoomed in after u snap the shot ...
Once you've framed your shot (zoomed in) and taken the picture. That's it, the picture you've taken is the one in your view finder, and that's the way its kept.
However, if you want to zoom in further, you can using the software you were provided with your camera, you can, you can also zoom in using your camera menu. Once happy you can then save the edited picture. But this time its a digital zoom and it will reduce the resolution. The picture won't look quite as fine. It will be a balance between picture quality and the extent you want to zoom in.
Apr 19, 2011 | Olympus PEN EPL1 Body only Digital Camera
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
SONY BRAVIA KDL40D3100
These new LCD televisions have a number of display modes, some which magnify and crop the video. You must have one of the magnification modes on, something called "wide zoom". As a result, some of the text is getting cropped because the whole picture is actually cropped (you just didn't notice). Use your remote and try changing the display mode. You should be able to get to "normal" and then basic wide (not wide zoom). Try it out. :-)
Dec 14, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Full screen problem
These sets work best in their native mode. Your DVD player most likely cannot address the set in its native mode.
When not in the native mode, the aspect ratio has to be compromised.
You should call Viewsonic for more detailed information and if there are any offsets that you can adjust.
Jerry G.
May 29, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Locked symbol on TV screen
in the remote for your telly there should be a button marked 'display' or 'disp' or a small square with + sign to it--when you have that padlock on the screen just press and hold that button for 5 seconds, that should unlock your tv
Apr 21, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Televison & Video Logo
Top Televison & Video Experts
