Question about Kodak Easyshare C813 Digital Camera
Help Turning my camera On
How do I turn on the "Easy"Share C813 camera? The batteries and the memory card are in properly and I'm pushing the ON button on top and nothing happens. Help please.
  • 1 more comment
  • tntklein Sep 09, 2008
    Having the same problem - have tried different batteries; might be a problem with the contacts when you slide the batteries in, as I can occasionally get it to work, but not consistently. I can "smack" the area around the battery latch and it will sometimes allow me to power it on, but have not taken it apart to investigate. I also bought a Kodak battery thinking it was designed to fit better, but have had no luck there either.
  • MMCA1 Sep 30, 2008
    Same problem. I have changed the batteries and checked the contacts. I just cannot get it to turn on.
  • jeffcd19 Nov 24, 2008
    My camera was shipped to me from Air Miles and it worked for 3 days then it wouldn't turn on. I sent it back to Air Miles who were very good and they shipped me a new one. After having it for 4 days, same problem. I took a grand total of 4 or 5 pictures, hooked it up to my Mac via the usb cord that came with the camera and a day or two after that it wouldn't turn on.  I am now trying to get Air Miles to take the camera back and re-imburse my Air Miles so that I can buy another manufacturers camera. Sheeesh
Hi , I had the same problem ,Kodak advised getting re-chargable batteries Mah 2500 ,normal batteries just are not powerful enough. Mine works fine now
Posted on Jan 24, 2009
Kodak easy share is frozen on the Easy share page
Remove the battery and the memory card, and disconnect from computer, now push power and hold for at least 60 seconds to reset the processor ic, install memory card and battery, turn on camera settings should return to normal, if not! the systems control board is the problem.
Apr 16, 2012 | Cameras
How do I download pictures from my Kodak easy share c813 to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 06, 2011 | Kodak Easyshare C813 Digital Camera
Need to install driver for mac for the kodak easy share digital camera
http://support.en.kodak.com/app/answers/detail/a_id/16433/kw/c813
You might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or any other photo cataloging program.
Nov 30, 2010 | Kodak Easyshare C813 Digital Camera
When camera is turned on it says memory card is
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Jul 21, 2010 | Kodak Easyshare C813 Digital Camera
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Mar 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
How to transfer pictures from internal memory to memory card (Kodak easy share C813)
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 09, 2010 | Kodak Easyshare C813 Digital Camera
When i turn my kodak easy share C813 on it says
take out the battery and set your mode dial to auto and put the battery back again and turn on your camera.
Aug 19, 2009 | Kodak EasyShare CD33 Digital Camera
Camera wont turn on
pull out slightly with a pin the two gold contacts on the battery door
Jan 27, 2009 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
