Question about Polaroid FLM-3734B 37 in. LCD HDTV
37" Polaroid Television repair please walk me through it.
I need help. I took the back panel off. I see two boards the top board has some black ribs on it that look like heat exchangers. It is smaller than the bottom board. I see two green capacitors side by side on the top board. Are these the correct capacitors. The is another larger cap. about an inch below these two should it be replaced also. Or am I looking at the wrong things?
I think your looking at the right thing. What does it say on the capacitors? 10v 1000Uf??? If that is what is imprinted on it then you have the right ones. Use 35v 1000Uf as replacements though.
Posted on Sep 02, 2008
Polaroid Flat Screen TV not working
Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter card to replaced.The board shape is a long board.
Apr 05, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
POWERS UP BUT NO PICTURE OR SOUND WILL NOT SHUT OFF POLAROID 37" HD LCD TV-2 YEARS OLD
my POlaroid 37" did same thing blue light stayed on no pic or sound was 2 electrolytic caps on power supply board took back off and they were noticably bulged at top radio shack sells these caps at $3 apiece fixed mine works like new saw a video on here how to do it
Dec 07, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Hi there. My girlfriends 2003 TTM Polaroid TV DVD Combo does not turn on anymore. She told me that the TV started switching channels, therefore she turned it off. It would not turn back on and still does...
If yours is anything like my Polaroid FLM-373B 37", I had the same type of problem. The problem with mine was two capacitors on the display board. Took me about an hour and less than $5.00 to fix. You have to take the access panel off the back. Mine was held on with three screws. You also have to take the display board out which mine was held in with four screws. The capacitors stand straight up on the board and are round with either black or silver colored on the top. Look for two silver ones that may be bulged on the top or are leaking. If you find this, that probably is your problem. I hope this helps. If you need more help, please let me know.
Oct 27, 2009 | Polaroid TTM-2003 Combo
I have to turn the tv on and off a few times
Just had the same type of problem with a Polaroid 37". Turns out it was two capacitors on the display board. When they go bad, they either leak or bulge at the top. They have to be replaced. You have to take the back access panel off to get to it. I wish I could give you step by step instructions on how to do this but I don't have them. Toshiba may also put theirs together different than Polaroid does. It only cost me about $5.00 and an hour to repair mine. Hope yours is as easy. I hope this helps you.
Oct 26, 2009 | Toshiba 32HL67 32 in. LCD Television
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
Polaroid FLM-3734B 37 in. HDTV LCD Television has a black smudge in the picture. The smudge never moves and is there no matter what we are watching. I fixed the sound problem, but now we have this.
Without actually seeing the problem, I can't be 100% sure, but this sounds like a defect in the LCD panel itself. Is there any possibility that you can post a picture of the problem? That would allow me to confirm the problem. Please note that if the panel is the problem, the set is not worth the repair as the replacement panel costs $2209.15 plus shipping.
Dan
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
I hooked my laptop up the to my tv the other day and the tv went black. Now only the 'red' light comes on - no picture. Does anyone have any ideas on what happened and/or how I can fix this problem?
Common problem with Polaroid 32 and 37" television. Problem is most likely the control board, at cost of around $400. physically disconnect power to television. keep disconnected for 30 min. Plug TV back in and turn on. That may fix the problem temporarily, but more problems are sure to come...
Mar 02, 2009 | Polaroid FLM-3232 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
