Question about TruTech PLV1615T 15 in. LCD Television
Fuse I replaced the fuse and the tv does not work still.
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Sep 02, 2008
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv at standby mode blown fuse fu120 2.5A.What next to do?
Unplug the TV from the power point.
Replace the fuse with the same value 2.5Amps
Do not put a higher value fuse in there because if there is a fault it may damage your TV.
When you replace the Fuse, plug the TV back into the power point.
If it works great, then it may have been a faulty fuse or power surge.
If the TV doesn't work then you may need a TV Technician to check the TV.
I hope this helps you.
If so please leave a vote or comment.
Have a Great Day
MobileJB
Jul 15, 2011 | Televison & Video
Is there a power fuse in this tv. sony 32" 1998 trinitron. Had great color, picture & sound. Will not turn on/no power.
There are fuses in most TV's... and in some cases, it's nothing but the fuse. BUT, the fuses are there to protect the circuits... so unless you know that there is nothing wrong with the TV, you shouldn't simply replace the fuse and plug it back in. However, if the TV is an older TV and it's either fix it by replacing the fuse or get rid of the TV... then I'd certainly take out the screws and check the fuses in the TV. But many times the fuse blows to protect it when something else fails... so if you find a blown fuse, look around for other signs.
WORKING ON ELECTRONICS should be done by professionals!! Proceed at your own risk!
Oct 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
How to replace fuse on sanyo tv DS 24424
Actually, when a fuse blows, most of the time there is something that went bad and is causing the fuse to blow. Some TVs don't use the typical glass fuses. Instead the might use a surface mount soldered component. These components are usually labeled with the letter F for fuse. Example would be F1 or F2. They are usually found near the power cord or near the power supply. Hope this helps...
Feb 01, 2009 | Sanyo DS24424 24" TV
Fuse keeps blowing out on Panasonic CT36HL44J TV
Thanks for this post. It inspired me to replace my fuse in my TV and it is working great now... I took pics of the process in case anybody wants to see what they are in for. http://joedotcom.com/2009/09/01/panasonic-fuse/ Although I did use a 6.3a fuse (just like I removed). I read on another forum that you can replace it with a 7a fuse and get better results. I have had this TV for years and this is the first blown fuse. If it becomes a reoccuring theme, i may up it to the 7a.
Jan 14, 2009 | Panasonic CT-36HL43 36" TV
Panasonic tv CT32SL14J
You'd better make sure that there's no power on in the TV by checking the red light in front of it. If it's sure there's no power when the TV's plugging in the outlet, then the problem may be the fuse.
The GLASS fuse locates right after the power cord where is connected to the TV. Using a screw driver to open the back (make sure the power cord already taken out from the outlet !), try to have the power cord side opened as wide as you can. You can use your finger tip to push straight from bottom to up to take the fuse out. For sure, you can see the fuse having the core disconnected in the middle.
To my case, the fuse was 6.3 Amp and 125 Volt, but I can only get the 6.3 Amp- 250 Volt at my local Radio Shack store. However, it's fine to replace with this higher volt fuse.
It costs about 4 bucks for a bag of 4 glass fuses. Worth to try with the "practice" and for having your TV back on again !
~NDo~
Feb 24, 2008 | Panasonic CT-32SL14 32" TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
