Question about GE Refrigerators
On TCD18PAD BWW refrig with freezer (drawer, not door) on bottom, water accummulates in bottom of freezer and freezes into ice which some how thaws with water flowing out bottom of drawer door onto kitchen door. What's wrong and what do I do about it? Can I fix something myself??
  • Anonymous Oct 06, 2008
    I'm having the same problem with my TCD18PAD BWW. I called for service. All he did was chip ice away from the evap fan so it would turn again and put it back together. I left it unplugged for a day to let the rest of the ice melt out. Now it is running again, at proper temps, but still draining excessive water in the freezer compartment, which is building up as ice on the bottom. It is getting very close to coming out the door, onto the floor after only a day and a half. Thanks for your help/ideas in advance.
You have a clogged defrost drain tube. On the back of the refrigerator in the center, about two feet above the floor, is a 7 inch by 7 inch square steel cover held on by four screws, one at each corner. The defrost drain tube emerges from the bottom of this cover and terminates loose in the drain pan below the refrigerator. Remove the cover. Underneath is the plastic defrost drain tube fixture, which is held by two screws. Remove the screws and take off the drain tube fixture. This fixtue is clogged. Run hot water and dish detergent through it and blow through it at the big end to remove the clog. Reassemble. That's it. You don't have to take the refrigerator apart. One caution. When the refrigerator has a clogged drain tube, the defrost water will back up and freeze around it. So you may need to empty your freezer and unplug the refrigerator for eight hours or so first before you perform this procedure to allow all the ice around the clogged drain fixture to melt.
Posted on Dec 22, 2008
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water is being dispensed from the water dispenser, but the Ice maker is working. Replaced the filter and still no water. When the dispenser is depressed, you can hear a humming noise but no water...
Start by : at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . Ge also has a dispensor heater , pt # WR49X10173 , with instructions , to keep this freezing from happening again , if this is the problem .
Jan 20, 2010 | GE Refrigerators
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker works fine but no water at door. Have water at bottom of door at quick connect but not at dispenser.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also , a dispenser heater , pt . # WR49X10173 , which comes with instructions , to keep this grom happening again .
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Water stopped coming out of the front
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
557 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
