My whirlpool top loader won't agitate.
Whirlpool LBT6133AWO CC4104141  Everything works except the agitator post.  THe agitator in the bottom of the tub works, but the agitator arm is so loose that it doesn't move and therefore the clothes aren't moved through the water during the wash cycle.  The spin cycle works, it is just the wash cycle.
We just washed a huge down comforter, could we have done something to the agitator - moved it off of a locked position?
Top part of agitator does not work but bottom part works fine.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
You did nothing to cause this! Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is broken!
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I
Posted on Aug 31, 2008
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load whirlpool agitator isn't working. Have replacement dogs but I cant figure out how to get to the agitator. Beyond the fabric softener dispenser
The following link explains step-by-step how to replace the agitator dogs on a Whirlpool top loader:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
You can find exploded view illustrations of your washer at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Enter your model number and use these illustrations to assist you with disassembly and reassembly of your agitator (if needed).
If you have any questions, please post back and let me know. I hope this helps you.
Apr 30, 2010 | Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Problem for Whirlpool LXR9445JT Top Load Washer Whirlpool top-loader LSQ9200LQ0 The top half og the agitator is not turning.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washing machine - agitator does not turn
If it does not drain, I'd check the water pump first (for an obstruction - I found a sock in my pump and that fixed my problem) ... see this video - the top is getting to the WM drive shaft (transmission), but it shows you how to remove the pump first: http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=related
If it does drain ... Is it just the TOP part of the agitator not working, or the whole thing (agitator is in 2 parts)? If just the TOP, you probably just need new "dogs" (agitator dogs). Check this out:
http://www.youtube.com/watch?v=V5wIN1J70-Y ... it shows you what to do.
If it is the whole agitator that is stuck, that video will show you how to remove it (remove a single bolt) and you can see if there is an obstruction keep the agitator from moving.
If there's no obstruction or the water pump isn't stuck, you might be looking at a new drive/transmission = expensive. Good luck
Jul 02, 2009 | Whirlpool Washing Machines
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Sounds like what you have is a dual agitator, bottom moves back and forth in wash, top acts like a screw pulling clothes down to the bottom of the tub. If so, the agitator dogs are bad, to get to them, pop off the cap on top of the agitator, then reach down inside and pull up a cap in there, then use a socket (I forget the size) and a long extension to unbolt the agitator and pull it out, the dogs are located between the top and bottom sections. They are slightly curved rubbery plastic pieces, 4 total. About an 1 1/2" or so long, one end fits into a hole on the inner part of the agitator and the other end is ribbed to catch the outer part of the agitator during the wash stroke.
Nov 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Oct 12, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
