Question about Nikon D50 Digital Camera
Nikon D50 Set Problem - Won't Take Pictures
Either blinks OFF in the top left end of the monitor (next to the battery symbol) or F-- in the top right. Wouldn't take picture in either condition, which seems to occur randomly (but way too often for comfort, had to get a small back up camera not to have a holiday ruined). Switching on/off, taking out and recharging the battery, resetting didn't help. Mine is not a body only, though, a set bought in 2005.
  • 3 more comments
  • Faralya Sep 13, 2008
    Apologies for being out of touch. It does seem that the lens was a problem, cleaned the contacts and reattached the lens corectly (it was slightly off max f18 aperture). Has been working since, but I haven't tested heavily yet.
    I had the camera since 2005, and the problem first appeared in 2007.
    Many thanks for your help; will let you know if the lens solution stops working, but so far, so good (fingers crossed).
  • Anonymous Nov 27, 2008
    will not fire.  error fe e
  • Anonymous Nov 28, 2008
    I had this exact problem...tried everything until I came to this site.
    Worked like a charm....took lens out, cleaned off contacts carefully, reloaded and...it works now. Thanks for a great solution.
  • Anonymous Feb 06, 2009
    Sweet! Worked perfectly, thanks a lot!
    Thanks a lot! Worked perfectly!
The F-- error means that the lens is not communicating or has lost communication, with the body. I would first try cleaning the contacts on the lens and body. You might also try another lens. This problem has been known to develop when using a heavier, large lens. It seems like you have had the unit for a number of years. Has this always been an issue?
Hope that helps,
-WN
Posted on Aug 31, 2008
  • Anonymous Sep 04, 2008
    Greetings,
    Did you have any success with the solution I provided? Your feedback helps me help others. Thank You
    -WN
I had the same problem, and the solution worked great for me. Just took off the lens and popped it back on and it started taking pictures again.
Posted on Oct 14, 2008
Can't take pictures Full is displayed
This could mean exactly what it says...that your memory card is full and pictures need to be downloaded to your computer. If you've already done that, it may mean that you did not tell the computer to erase the pictures from your card.
If that's the problem you should be able to fix it by formatting the card. You can do that from the menu(little wrench icon) or by pressing and holding down the "delete" button (trash can icon on back of camera) and the "metering" button (to the left of the off/on switch) on the top of the camera. Both buttons are marked with "format" symbols.
If neither of these works, try replacing the card with a new one that is known to be empty and known to work.
The final alternative is to contact Nikon tech support at www.nikon.com and see what they advise.
May 12, 2013 | Nikon D50 Digital Camera
Dropped my Nikon D50 and now it shows there is no SD card in it and the battery indicator is flashing. Nothing appears on the LCD - including the menu. I've taken the SD card out and the battery and...
Contact Nikon tech support at www.nikon.com to see what they recommend. I don't think the warranty covers abuse such as dropping the camera so you may be in for an expensive repair. However, he Nikon techs may be able to suggest something that might help you avoid that expense.
Mar 01, 2013 | Nikon D50 Digital Camera with 18-55mm Lens
I have a nikon D50 with the original lense. I have a battery that has been tested and works fine. when I put it into the camera the camera recognizes it there by telling me how much space i have on the...
Do you mean the camera can't works well with your new Nikon D50 battery? But how about your original battery. Maybe your new battery is not so compatible with your camera so the camera can't recognizes the whole information on the Nikon D50 battery chips.
May 09, 2011 | Nikon D50 Digital Camera
My Nikon D50 locks up intermittently
you like to try and swapping batteries.. i guess it couldnt supply enought power to the shutter motor.
Aug 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
No picture in the image screen
I suspect that you're looking for a "live view", like in the point & shoot cameras. Most DSLRs (like the Nikon D50) don't have live view. In other words, in order to see the picture you must take it first.
Dec 01, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50
I have this problem too - Nikon have looked at the camera and said I set up a custom setting so that the focus only works when you press the AE/AF Button (!). I also had a problem with the flash not working - its looking like this is a known problem. I think I was sold a Turkey
Apr 19, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
459 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
