Question about Averatec 6200 Notebook
Averatec 6200 Laptop wont boot keeps going back to same screen when i put windows xp pro in dvd drive all i get is black screen _
  • Anonymous Dec 16, 2008
    My screen go black after starting
  • Roberta Smith
    Roberta Smith May 11, 2010
    what screen does it go back to ? also make sure it boots to the cd rom if you are trying to do an install
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
Posted on Jul 25, 2009
Ok, thanks for the response. now, can i do a clean reinstall of xp, and if so, how?. do you have a link of the steps? thanks, tommy
Re-installation of Win XP is simple. First you need to back-up all your important files and secure your XP cd and device drivers. If you have done all, just follow these steps:
1) Insert XP CD on CD/DVD ROM and boot from it.
- to boot from CD/DVD ROM you need to press F11 during start-up. This will open the boot sequence and will let you choose which device to boot from. Just choose CD/DVD ROM from the list
2) A blue screen with white text below will appear. Just wait for the instructions to come and follow it carefully.
3) The first instruction would be "Press Enter to install Windows XP". As what it states, press ENTER.
4) The next instruction would be to partition your drive. I recommend yu make a partition if you have a large capacity storage. Just follow the instructions on how to do the partition.
5) There are several simple instructions after you make a partition and make sure you follow it. You will see copying of files, still in blue background and white text.
6) After finish copying of files, the computer will restart automatically. This time, let the computer boot by itself. Don't boot from the CD/DVD ROM. This will go inside your Windows XP operating system and will continue to install remaining things.
7) Once again, just follow instructions like entering time, date, administrator passwords and so on.
8) You'll be waiting like 39 minutes more for this.
9) When it prompts that your computer is now ready, go ahead and install your device drivers.
10) That sums up the summary for the installation.
Hope it helps.
Let me know.
Thanks for using Fixya!
Feb 25, 2011 | Averatec 6200 Notebook
Hello. windows xp tries to load, otherwise, nothing but the floating "dvd video" on the screen. the owner told me he "killed it" with too much audio. can i replace the cpu and reload...
I would have thought that if you are getting a floating DVD Video on the screen, it has past POST and the CPU is OK.
If you are getting as far as booting, the CPU must be OK and it has a software issue.
Feb 24, 2011 | Averatec 6200 Notebook
It wont load windows xp even with the recovery disc it just keeps saying boot with any key
You may have set the boot priority in the CMOS. If so, enter the CMOS setup and set the priority to "boot from HDD" This may not fix your problem, but it is a start. If it still wants to boot from another source, the HDD master boot record (MBR) is corrupt, or the HDD has failed.
Mar 17, 2010 | Averatec (70-822301-00TRI) (7082230100TRI)...
My laptops dvd cant work.
Solution :
1) 1st we can uninstall and reinstall the cd/dvd drivers
2) upper filter and lower filte
· SEARCH BUTTON
· REGEDIT
· HKEY_LOCAL_MACHINE
· SYSTEM
· CURRENT CONTROL SET
· CONTROL
· CLASS
· 4D36E965
· NEW WINDOW
· 2 OPRIOND (DELETE ALL UPPER AND LOWER FILTER)
restart
3)
Take out the optica drive and put it back
It should work
thank u
Dec 15, 2009 | Averatec 6100 Notebook
On-screen cursor jumps around while typing. When I am typing I end up typing in the middle of previous typed lines. I have a Averatec laptop running Windows XP)
Try using the function key to disable the touchpad. Most times they are sensitive and like to jump when you are typing as your wrists rub or pass over the touchpad.
Dec 09, 2009 | Averatec 6200 Notebook
My windows Xp just lost because of power failure.. how i reinstall the windows xp for my laptop of NEC Versa pro NX
have you tried this ......
restart the laptop press F8 it will open to boot the laptop through various process like safe mode , last good known ..... select the last good known option and press enter .... it will boot the laptop with last setting
if this one not working then go for reinstall of xp ...for reinstall xp
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  6. Follow the instructions on the screen to complete the Windows XP Setup.
Nov 25, 2009 | Office Equipment & Supplies
Averatec 6200 rw dvd drive doesnt work
YEs, typically that sound means the Hard Drive crashed. Although you may be able to still use it, its not recomended. Hopefully you backed up you important files because most likely they are un-recoverable. Does the laptop boot at all? If so, do you get a hard drive not found error? any errors?
You can easily replace a hard drive on a laptop. usually you just remove a small screw and pull the old hard drive out and replace with a new one.
Go to any computer store or if you can, order one online as it may be cheaper.
Order a new one, get one with more hard drive space if you want, especially if you have alot of files.
Make sure its the right type of Hard drive as well. I.E. SATA or IDE. If you dont know, then take your old hard drive with you to a computer store with knowledgable techs who can get you the right one. Typicall you can get an 80 gig hard drive for under $60 depending if its a SATA or IDE and what speed it is.
Keep the old one untill you know the new one is the right one in case you have to compare it again with another one.
You will have to re-install your operating system ( Windows XP, Vista, ETC. )
then once all that is done, you will have to go through the task of re-installing all your software, printers and files.
Hope you kept that re-install disk that came with the laptop, that has your hardware drivers and Operating system on it.
Dont be affraid to look at the specifications of the laptop in the owners manual or to take that with you when you go looking for a new hard drive.
Being knowledgable about what your looking for helps to keep sales people from selling you more than what your looking for.
Tigerdirect.com and Newegg.com are two placethat have the item your looking for and usually at a good price.
Good luck.
Dec 01, 2008 | Averatec 6200 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Troubleshooting my Laptop "AVERATEC' 3200 series
not good..do you have an install disk around or a recovery disk?
Feb 22, 2008 | Averatec 3200 Notebook
Averatec 3250 laptop
I think you may need to repair your installation of windows XP or if that doesnt work, just reinstall it fresh.
Nov 18, 2007 | Averatec 3200 Notebook
Averatec 6200 Notebook Logo
159 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
