Question about Sony Cyber-Shot DSC-F828 Digital Camera
F828 autofocus assist trouble! Help!
Recently my autofocus has stopped functioning completely. Instead of the assist laser illuminating until it has focused it only blinks on for an instance and then goes off without focusing. I have cleaned the assist window. No luck. If I turn the autofocus assist off it will focus in dim light but not where it's too dark to see of course. If anyone has any information please let me know. Thankyou!
    Master:
  • 551 Answers
I would also try to RESET the camera, sometimes it helps and you cannot make it worse I believe. Good luck
Posted on Sep 12, 2005
    Master:
  • 551 Answers
This is probably a dumb question, but that little auto/manual focus slider doey isn't in a betweenie state, maybe not engaged or with a little grain of sand keeping it from making contact one way or the other? Just a thought..
    Master:
  • 551 Answers
This is very odd as you know - have you tried testing it in sunlight against a high-contrast target like a newspaper even or trees,etc? Something that will be easy for the AF system to catch onto. I find my 828 will focus anywhere in the zoom if there is something with enough edge definition it can latch onto. If you've already tried all these things and it's still a problem, i fear it may need sony's repair touch..
    Master:
  • 551 Answers
This is strange. I can't imagine how you could have caused this. As far as I know, there aren't any controls you could have changed that would give you this type of result. Even with Macro enabled, you can still AF throughout the focal range. If you were accidently in MF mode, you wouldn't get a good focus, at either end, without turning the focus ring. Unless someone else can shed some light on this, I think your camera may need to go visit Sony's repair center :-(
SOURCE:
When I press the shuuter button down my D80 flashes a bright light. I have tried switching the modelling flash function to off, however this has not solved the problem?
That's called an "autofocus assist lamp". When you prepare to take a picture in low light, the autofocus can struggle to lock on to your subject. The lamp you talk about, illuminates the subject for a moment, so that the autofocus can 'see' when correct focus has been achieved.
It is indeed annoying, but this is the price you pay for sharp photos (it's not possible to wait for the flash to go off, and focus in that moment). One 'solution' would be to turn the focus assist lamp off and live with the poor results. Another 'solution' would be to switch to manual focus. Or you could let the camera focus normally once, apologise to your subject, turn the focus to manual without changing it, and then taking more pictures without the annoyance (but you might have got a good picture the first time, anyway).
Jan 20, 2011 | Nikon D80 Digital Camera
Each time I press the shutter button to take a picture the flash keeps flashing fast on and off 3 bursts of about 10 flashed then it takes a pic ??? help
The built-in flash can function as an autofocus illuminator. This helps with focusing in low-light conditions in the AF mode.
To disable this function, press the menu button, then select service1 menuitem, then AF illuminat., and finally, select OFF.
Aug 20, 2010 | Olympus EVOLT E-410 Digital Camera
I need the codes for my jensen JER 422 remote
For a manual code search and entry:
1. Turn on the component
2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL)
The illuminated on-off key turns on and stays on
3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5. Release both keys. The illuminated ON-OFF key remains on
6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.)
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved.
8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed.
Try this too:
In step 6, instead of pressing the on/off button, press the Play button. The on/off button will blink several times as a chunk of codes are sent at a time. If your component turns off, press the Reverse button (slowly) until your component turns back on, then press Stop to save the code.
Basically this does the same thing, but it goes through the codes...ten at a time, I believe. The only time you're going through them one at a time is when you are pressing the reverse key.
Dec 16, 2009 | Jensen JER-422 Universal Remote Control
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Help
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Jul 20, 2008 | RCA RCR311B Remote Control
Help
Jul 10, 2008 | RCA RCR311B Remote Control
What functions i can control with remote in f828?
Regarding remote control, sorry to say but it's very limited. With RM-VD1 you can only: ON/OFF Shutter release 1st and 2nd step Zoom in/out (except with F828 which has manual zoom) Rec/Stop (only with a camcorder)
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
F828 and ISO question
because you are (a) opening the lens aperture to let in the maximum light and (b) making the sensor more sensitive so that it requires less light, so the camera must do what it can to counter your settings - to reduce the light by minimizing the time of the exposure. I presume this is a hypothetical question, as you don't normally want to use ISO this high with the F828 if it can be avoided.
Sony Cyber-Shot DSC-F828 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
