Question about Dryers
Conecting a 220w plug into a standar wall plug
  • 706 Answers
If you are using an elctric ( not a gas) dryer then never try to plug the power cord of that drywr into a 220VAC wall receptacle. It isn't rated for the appropriate current that the dryer requires..However if yiou have a dryer that operates the contro system and is NOT a Gas dryer than you will need the proper plug end that matches the receptacle on your wall. Most harware stores should carry the right plug. I do not know what country you wrote your problem from and there are different power grids throughout. In general though, if you do have the right plug that matches your wall receptacle and it has 3 prongs... the two side prongs are normally the power and the disimilar prong is ground.. Can't help you with any additional details without knowing what you are confronted with..
Posted on Sep 01, 2008
What are power supply specs for hp Slimline s5200z
HP say only that the psu is rated at 220W
(http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01911671&lc=en&jumpid=reg_r1002_usen_c-001_title_r0002#N121)
I
I rather think the specs are the same as this one and that themodel number is the model in yours
http://www.ebay.co.uk/itm/HP-Pavilion-SlimLine-s5000-220W-PSU-Power-Supply-HP-P-N-504965-001-PC8044-/221182783648
HP Pavilion SlimLine s5000 220W PSU Power Supply HP P/N: 504965-001 taken from computer when hard drive died in full working order has been cleaned ready to be reinstalled Model:PC8044 HP P/N:504965-001 AC INPUT:100-240V, 50/60HZ, 6A DC OUTPUT: +3.3V 16A +5.08V 15A TOTAL110W MAX +12.0V 16A TOTAL210W MAX -12.0V 0.3A +5.08Vsb 2.0A
However to certain take the panel off yours and have a look at yours
The are plenty of higher power replacements available search the internet for eg "what psu is in a hp s5200z"
20.December.2014
May 20, 2014 | HP Computers & Internet
Replace power supply
Are you sure the power pack has failed? That should be straightforward and fairly cheap. Note carefully the model and type on the present one, then shop around.
  • Power Supply
    Internal 220W (100V-240V)
    Form factor: Internal for slim form factor
  • Total wattage: 220W
  • Nominal input voltage range:
    • 100-127V/6A (50-60Hz)
    • 200-240V/3A (50-60Hz)
  • Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
  • This power supply has an LED to indicate a possible failure condition when the LED is off and power is connected.
Feb 20, 2014 | HP Pavilion Slimline s5710f Desktop PC
The transmision is standar or electric
Most newer cars have no dipstick, contact the dealer or check your owners manual for more information about adding ATF.
Aug 23, 2012 | Cars & Trucks
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
I have the sound but cant get the picture on screen,is this a common problem?
it may be really simple. check at the sweetch at the end of the video cable, the end that connects to xbox. it has a sweetch for standar quiality and dh quality (standar you will use only 3 cables, hd you will use 5 cables)
if you are using 3 cables (yellow, red, white)
you may have the sweetch on HD you will Hear sound but not video
if you are using the 5 HD connector (red, white, red, green, blue)
and you sweetch is on standar you will have sound but not picture :)
i hope this solve your problem
remember if i help rate me.
thank you
Oct 09, 2009 | Microsoft Xbox 360 Console
How change from hdv to estandar definition
In this type of camcorder The lower video quality.
Standar Quality o standar definition will be 480i setting.
in the setup menu it will be an option to change the size of the picture to 480i. thas the standar o lower quality if you want to have a longer recording time in this HD camcorder
Recording modes
1080i (1440x1080), 1080/30p, 1080/24p (via 2:3 pull-down), 480i
Oct 07, 2009 | Video Cameras
How do i connect advent pc to philips hdtv. do i need to change settings?
well not really, you need to buy the proper cable depending on the inputs of your tv, it may have the standar VGA connection as the standar pc monitor.
DVI to VGA cable
DVI to DVI
HDMI to DVI
HDMI to HDMI
after you have the proper cable just plug it, and turn it off, disconnect the standar computer minitor and turn it back on. the computer will set the input signal from the tv by itself.
thats for the video, for the audio you need a different cable
3.5 mm to RCA (white and red cable)
3.5 mm to 3.5mm headphonejack cable
but if you are using the HDMI to HDMI you don't need a sound cable.
Oct 07, 2009 | Computers & Internet
Microsoft office 2007 standar
i need a 25 digit key for ms office 2007
Feb 26, 2009 | Microsoft Office Professional 2007 Full...
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Dryers Logo
81 people viewed this question
Top Dryers Experts
