Question about Acer Aspire 5520-5908 Notebook
Back up disc wont work
I tried to reboot my computer(an aspire 5520-5334) get first disc to download but get an error on second disc had to put basic on the computer just to find a cure
    Problem Solver:
  • 6 Answers
Downloads are not full so they will have errors
Posted on Nov 10, 2008
Aspire 9412awsmi wont start
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. 3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. 4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
Apr 07, 2013 | Acer Aspire One PC Notebook
How do i fix a disc error on my acer aspire
Make sure you do not have any devices plugged in to the computer like a USB flash drive or a MMC. Usually what you have to do about that is to drain the power of the computer. Turn it off, remove the battery, unplug the AC adapter and then press the power button for 5 secs. Turn it on using the AC adapter alone. if you still get the same message, You will have to physically open the back of your laptop and reseat the Hard drive. If it still wont correct the problem, restart you computer and either press f2 or delete to enter the BIOS page. check if the HDD is properly detected and try to reload the BIOS defaults. now if any of these wont work, call ACER and most probably your Hard Drive is bad.
Jun 12, 2010 | Acer Aspire 3680 Laptop
Acer Aspire SA80 desktop: Trying to recover PC to Factory Setting
The error your getting means leaking memory,, replace the rams and it will complete restore..
NTLDR is part of the booting system of the computer..basically the computer cant find the file..
Contine with the system recover after you change the rams,, you'll be fine..
Mar 12, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My Acer Aspire 5920 won't do a recovery
BSOD is caused by hardware error or driver error. Disconnect all hardware except the basic. Motherboard, monitor, memory, hard drive. Unplug the wireless, cd/dvd drive.
Start the computer and see if the the BSOD returns. If not, one by one add components until you see the BSOD.
If you continue to see this screen without any hardware attached, then you most likely have an onboard component failing. (audio/video/memory failure)
Download and run the MS DART cd and check hardware starting with memory then hard drive.
http://www.microsoft.com/windows/enterprise/products/mdop/dart.aspx
This should determine what device is failing, except video or audio.
Jan 24, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire One XP startup error
if the laptop has a floppy drive get a bootable win 98 disk. insert disk first then turn on comp. run w/o cr rom support. at command prompt type "fdisk MBR" hit enter remove disk and reboot. if still bad insert win XP disk and do the second repair not the first one let it run its course. if not well you will have to reimage the comp
Jun 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3680 Wireless Not Working
The Aspire 3680's wireless adapter is not compatable with vista basic. You will need to go to acers website and download the newest patch driver.
Feb 01, 2009 | Acer Aspire 3680 Laptop
Wont start up
check whether the hdd is detecting on bios
Sep 24, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5520-5908 Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
