Question about iRiver H10 MP3 Player
Iriverh10 man i can not put music on my iriver h10 because i dont have the disk can u help????
Go to control panel/ add and remove hardware find the H10 and ad it it should install drivers from the net. You should be all good then.
Posted on May 07, 2010
  • 66 Answers
Google??
Posted on Sep 03, 2008
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
My iriver wont sync with WMP
try bringing your music up as a file normally it works cause with a lot of devices that's the only way you can send them so bring your music up as files then open your i river as files then all you have to to do is copy and paste
Oct 11, 2008 | iRiver H10 MP3 Player
DELETING OLD FILES THAT ARE NOT STORED IN MY PC
Use Windows Media Player to dleete the songs
May 19, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
My h10 will not switch on, iriver support will not help
Try to reinstall the software CD you received with the player. Good luck
May 01, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
67 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
