Question about Kirby Vacuums
Will not power up. Died a couple of seconds after switching on.
Motor died in use outlet ok. thinks larry
Posted on Sep 01, 2008
Has no power
Does the switch feel like it "clicks" when you turn it on? might be a bad switch. If the motor went bad then it's lights out for that vac.
Jun 09, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
There is no power...seems like a motor problem. The bag is clean...the mouth is clean the plug us in...NOTHING! I took mouth off and manipulated/pushed in that power press area that engages the motor on...
The front safety switch must be pushed in by either the hose or head (or manually), before the on/off switch will operate. The most common reason for no power is a bad cord. Second most common is worn carbons in the motor, and third is a bad switch.
Dec 25, 2010 | Kirby G4 Bagged Upright Vacuum
Plugged my Dyson in this morning, switched it on and power came on for not even a second and died. No power what so ever to dyson - checked my house sockets, changed fuse. Still not working - dead as a...
It is either your power cable, cable rewind mechanism or your motor.
Try switching it on, and wiggling the lead near the plug and see if it fires up. If it does, remove the moulded plug and fit a standard plug.
If not, likely suspect is the motor or the cable rewind mechanism. Neither are an amateur job. If you are in the UK, you could send it to Manchester Dyson for either to be fixed. Carriage will cost you about £10 each way. A motor replacement will cost around £65 and a cable rewind mechanism about £45-£50.
Nov 25, 2010 | Dyson DC08 Cylinder Bagless Canister...
All of sudden, the vacuum stopped. There is power to and through the on/off switch. Could the motor have just died without warning? Please advise. Thanks
Hi and welcome to FixYa, I am Kelly.
Very nice vacuum btw! These were the competition for the Kirby Heritage II models.
Most vacuum cleaner motors are brush type motors. If a carbon brush fragments then only one brush contacts the brush ring. If you read power at the motor terminal connection terminals in both the high and low switch positions there are 2 things that are left as the probable failure. Brushes, or motor windings. Resistance of the motor winding should be about 220 Ohms. There are 3 terminals on the motor connection. One common (neutral) and one for power (line) and one ground if you have a 3 pronged power cord. The same thing happned to my Hoover concept one... working fine and just stoped. In my case one of the 2 motor windings failed (high speed winding). I had used it just over 45 seconds when it failed so it did not over heat.
Thanks for choosing FixYa,
Kelly
Nov 23, 2010 | Royal 4000 Classic Bagged Upright Vacuum
I have a dyson dc05 absolute turbobrush vacuum. turned it on and it slowly died in seconds. then tried to turn on again and only came on sporatically for a moment. Is it the on/off switch or motor?
Hi there VacuumGuru for vacuumspot.com.au here. It is likely to be the motor for that model but it is easy to test. I will answer this with the assumption that a person wouldn't try to repair something they are not qualified to do. All you have to do is disconnect the wires off your switch and join them together (with power cord disconnected from socket obviously). Then plug you cord in again. If it still plays up then it is your motor if its fine replace your switch. We stock switches and the motor for that machine if you live in australia by the way.
Vacuumspot.com.au
Hope this helps.
Oct 14, 2010 | Dyson DC05 Bagless Canister Cyclonic...
After a couple seconds that it is switched to
You need to replace the belt(s). Here are the belts you need and the manual with instructions:
Dyson DC14 Belt
Jan 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
My vacuum died. It won't turn on. It is not the outlet. Is it a blown fuse? How do I replace the fuse? Where does it go? This vacuum is a little over 2 years old. My older Hoover WindTunnel STILL works and...
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Jul 09, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
My hoover power drive vacuum simply died. It just shut off. I checked the plug, etc...I just can't get any power...Can you help?
If no light or motor sound cord is probably bad. Look near AC plug or just replace the plug end. Check with ohmmeter for continuity with switch ON.
Jan 24, 2009 | Hoover U6311-930 Power Drive Bagged...
Vacuums Logo
35 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
