Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Double picture my friend chanche the convergence on my jvc model#av56wp30 but i still have double picture he told me change the resistor but i dont know what kind my tv need I have a AV-48WP34 with a double picture on it with a red tint
  • JVC Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
double picture - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
SOURCE:
How to adjust the convergence on jvc av56wp30 hdtv
Start in the center of the grid and work you way out in circles....do small adjustments....its better to make several passes...Look on the tv repair tips page on www.TvRepairKits.com for more info.
Jan 29, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Was convergence problem now dont know
often on that model the DCU which is on that same board is where the problem is especially if new ICs and resistors dont fix the Issue. The DCU is the metal cased unit which is next to the Convergence ICs heatsinks
Mar 14, 2009 | JVC Televison & Video
My 56'' jvc av56wp30 tv screen is doubled only twords top o screen
*Screen Looks 3-D
*Colors wont align
Nov 19, 2008 | JVC AV-56WP30 56" Rear Projection...
I have a JVC AV-56WP74 that all of the sudden has a bow screen on top and bottom with green and purple tint with double picture. I have tried to fix the problem working with the convergence troubble...
You need to replace both convergence ICs they are STK392-110 you may want to get the resistor kit as your model will usually have a couple open resistors. You can get replacement ICs and resistors at the following link and they provide free instructions with pictures so you can easially do the repair your self.
Heres the link.
http://servicemanuals.vstore.ca/
Aug 13, 2008 | JVC Televison & Video
I ART PRO JVC 56
You will need to replace the convergence iCs there are two of them they are both STK392-110 Ics you will also need the JVC convergence resistor kit. You can get the ICs and resistor kit at the following link and they provide free instalation instructions with pictures. Heres the link.
Jul 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Double picture
does your TV has the stat adjustments in the CRT or near the chroma IC it is a trimmer resistor or a rheostat try to adjust it...
Jul 26, 2008 | JVC AV-56WP30 56" Rear Projection...
Double Vision ...w/waves on top/bottom too much green.
1024x768 Normal 0 Convergence
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jun 05, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
192 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
