Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore model #106.52693100 compressor too hot
Hi;
I had a problem with my kenmore refrigerator model # 106.52693100, first I some clicking sound at the back, so I opened back panel and found out that relay was fried, change the relay, and the compressor starts fine, freezer was cold but refrigerator side was warm, also the compressor is getting hot and the panel between the 2 front doors are getting too hot. I heck the fan at the back and the fan is running ok. Any advise what is going on.
thank you
  • lionpride Sep 22, 2008
    I noticed that the panel in between the two doors was really hot today on my Kenmore fridge. It's bedtime now & my husband & I unplugged the stupid thing b/c I'm afraid it's going to catch fire. I looked at some other sites with some scary comments about similar problems like this; it doesn't look like Sears is the responsible company they used to be.
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
Tech007
  • 63 Answers
SOURCE: Kenmore Refidgerator is not cooling
let fridge cool down it sounds like the relay overload is bad try replacing it with a 3 n 1 start kit directions on the kit real easy to hook up... if the compressor starts then you are ok... hopefully the compressor is not burned out good luck
Posted on Aug 29, 2007
watugot
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
peyton32034
  • 410 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Posted on Dec 18, 2007
  • 236 Answers
SOURCE: Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
Fridge and freezer are not cold. Stopped working all of a sudden. Unit runs but sounds like compressor will not stay on. Compressor tries to start for about 10-15 seconds then shuts off. Compressor is...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 12, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My fridge and freezer do not seem to be cooling. Lack of air flow possible compressor failure. Looking for any solution I could try at home.
OK I will give you a try and see if I can help. Kenmore is a Sears Brand name as you already know. What happens is Sears call their models something different than the number I or you need to make a parts search. Click Here=> Sears Kenmore model Number Prefix and complete Model Number As you see in the photo about mid page the sample number is 795.78753800 so the prefix is in this case a 795 LG Electronics Refrigerator. Once you locate that number I will want you to unplug refrigerator and pull away from wall. Remove the lower cover over the compressor area to expose compressor, condenser fan and condenser coil. Fill the top of your compressor to see if warm, hot or too hot to keep your hand on top of refrigerators compressor. If too hot to keep hand there leave unplugged until compressor cools enough to open the cover on the terminal box on the side and we need to do some test from there. Click here=> How to test a Compressor for Burnout
Down on this Page Almost at Bottom. Don't worry this is only a windings test so you get an idea of what to look for.I want you to open freezer door and feel to make sure fans are running while compressor runs. I will await your response, Thanks, Sea Breeze
Feb 15, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a Kenmore fridge model 53542300 the fridge and freezer are not cooling I can not hear compressor running nor is it hot. I do see the fans running for Fridge and freezer. I went to check the start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 28, 2010 | Kenmore Refrigerators
I have a kenmore refrigerator, but for some reason it's not cooling. i've check back rear fan, it's working and i'v also check the inside fan removing the inside rear panel on the freezer side, and it's...
Is the compressor running?? If its hot but not running , humming and clicking sound you may have just a bad compressor relay. Or a bad compressor.
If your compressor is runing you have lost your freon.Leak or hole in system.
Dec 12, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Model # 10654502300 side by side
yeah your relay is burt out by the sounds of that
your compressor may be the cause, or it could be that the relay has just had enough
May 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Nov 07, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
