Question about HP Jornada 660LX
HP Jornada 660LX not working
My HP Jornada 660LX stopped working. I replaced the back-up battery, and all I get when I plug it in is a red light that is only half lit up. Tried hard reset, but still no success on getting it connected. Any help will be greatly appreciated. Thanks.
0 characters
1 Points
HP Jornada 720 handheld communication with pc.
This error is a communication problem between your computer and the Jornada. Try these solutions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpia2302&cc=us&lc=en&dlc=en&product=61677
Has anything changed that caused the problem, eg, installing new hardware, using a different cable to sync the Jornada?
Feb 21, 2008 | HP Jornada 720 Pocket PC
Blank Screen on Jornada 680e
need new screen ok get one off ebay
Jan 30, 2008 | HP Jornada 680e Pocket PC
Jornada 547/548
When you smell burning silicon thats a sure sign you are going to need a new one. Sounds like some pretty severe damage to chips if it smelled up the whole car. But the battery charging light still working is a good sign, which means its not a total loss.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Jornada 568 Sync Problems
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Jornada 680 "booting cold"
Sounds like a loose connector inside, I had a similar problem after I took my 680 apart to replace a cracked screen. It took a few more dismantlings and re-assemblings until it settled down. You should also check the state of the button cell battery.
Sep 12, 2005 | HP Jornada 680 Pocket PC
Keyboard problem
it's the same for me, but i figured out the problem came from the earphone jack, when i plug in to my television the electric spark caused that line of keys to stop functioning like normal, but after I discharge the jack with an ordinary headphone for a while, the keys back as normal
Sep 12, 2005 | HP Jornada 720 Pocket PC
Will there be a PPC2003 Upgrade for the Jornada 560 series?
my guess would be no seeing as it doesnt have Bluetooth or Wifi which the new Pocket pc is based on and needs bluetooth as standard i beleive. I would look for a new product not just yet though as not much at all supports ppc 2003 as this forum is slowy starting with the moans and groans of app incompatibility.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Battery problem
First I'd try a hard reset (tiny red button at the back), if that doesn't help, it is likely to be the battery.
Sep 12, 2005 | HP Jornada 540 Pocket PC
Deleted Items Sync
did u empty ur deleted items folder in outlook if u did to stop it from syncing the e-mails open up active sync and go to tools options and then uncheck the e-mail
HP Jornada 660LX Logo
21 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
