I have a sunbeam bread maker recently stop mixing at all except when i take the pan out and rotate the moving part by my hand then start mixing for a while then the same thing happen again i checked on the motor belt was fine and seem to work good i don't know what is wrong with it please help
you will have to decide if is cheaper to fix or replace. Microwaves are inexpensive. find parts and someone to fix it mat be difficult. I would reple it and move on. You can chose from several makers. prices start at $39.00 up to $150.00. look at Walmart, home depot
open the unit and check for an internal glass fuse on the control board,sometimes when they sit for a period of time the fuse wire deteriorates and breaks or by the initial current surge it can burn thru too
A very clever microwave, making bread! If and as I suspect you have a bread maker, the beater does clonk a lot as it mimiks the beating motion of making dough and proving. It will pick everything up and stir it in as it rises. Hope that clarifies for you.
Strange, that must be an old number or something, the correct number is 1-800-446-1898. It sounds like the timer has failed in this unit, I am surprised it still makes the bread properly. Please start with giving them a call and see what they say, it could even be under warranty, hard to say, even though you got it at an auction. Betty Crocker is very good with customer service and can probably help, but the unit is "broken" so to speak, it is nothing you are doing wrong. ThanksTim
It sounds like you did not press the select button for
the correct mode. If you select time and start the unit will only bake. I have the manual which I could send you in a PDF format if you
would send me your email. [email protected]
