Question about HP Jornada 620LX
Hp palmtop 620lx
How can i connect to my home network i use a dhcp router and all cpc are on workgroup can i use pcmcia lan card? if so how do you load hardware drivers
0 characters
1 Points
Hello, i have a hp Hp Ipaq 5455 and want to use a wi-fi connection at home and traveling.I can see the wireless networks and it says connected after i write the secret password that was given to me from...
I would say that either your password is not right either wrong or in the wrong "keyslot"or your hp isn't getting the proper numbers from the router. Since you can see them and connect we can be almost certain there is nothing wrong other than a setting.
Past that a incorrect password or on some wifis incorrect case of letters or wrong position would do exactly this. Basically every time your hp (or any other device) sends data to the wifi it will send the password info. It doesn't need to have the password to see or even connect but to get the data past what is basically a firewall it needs the key which is the password etc. Usually the case doesn't matter for most wifi routers but on some it does all the time and on others it does if they are setup that way. I've been caught by that more than once as case is unusual. To any electronic device Password and password are two totally different things. As well there are normally 4 key slots or positions that password is associated with. You can actually have 4 different pass codes as a result. And again even if the password is the same if it isn't in the right slot then the router will ignore it as it is incorrect. Basically you have to keep trying to enter it in while trying any variations. You can also yell and call it names. Doesn't help but can make you feel a bit better about this irritation ;-)
Last thing is that a lot of networks use what is called DHCP service or Dynamic Host Control Protocol. All that nonsense means is that when you get connected the router assigns the numbers to the device. That is how it is supposed to work. What happens on a few handhelds is that this does not want to work so what you have to do is manually enter in the numbers. You need a ip# (something like 192.168.2.10), a net mask (usually 255.255.255.0) a gateway number which is the ip of your router (will be something like 192.168.2.0) and then you need the DNS numbers for your ISP which will be sim in layout to the previous examples.Once you enter these in you will be able to connect to the lan and out to the internet. I still use my Palm Lifedrive and it has this issue on some routers. On the ones that I have manually entered them in the network runs faster so it is worth doing.
So you need to keep checking the password and slot (till it hurts) as well as considering putting in the numbers manually. If you need help with that you can reply here and either myself or someone else can assist with that.
Sep 24, 2011 | HP iPAQ H5455 Pocket PC
How to connect to internet via a notebook's wireless for HTC G1?
If you are looking for your laptop to do web via the phone, this is what you are looking for...
http://graha.ms/androidproxy/
IF you are trying to do Terminal Services or mail clients or non web TCP/IP, there should be some apps coming out soon for general IP stuff...
Ray
Jan 03, 2009 | HTC G1
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Archos 605 has 2 problems: 1: can't connect to wifi network at home. This is a netgear 614 router (which is quite old) with WEP encryption. Have tried to disable all security still no joy. Have...
the issues with the pda and wifi is most likely based on the 811 standards that each have...did you compare those two for 811 compatibility?
Apr 23, 2008 | PDAs
Can't get dynamic ip address
What about your desktop pc? Have you checked the services on it to make sure it is not broadcasting DHCP? Also, think about switching over to Stealth Mode (Non-broadcast SSID) instead of MAC filtering. MAC filtering can be cummbersome and if it is just you, then do away with it.
Sep 19, 2005 | HP iPAQ RX3115 Pocket PC
Restoring data saved on a Flash Card
The battery backup can be replaced by sliding the side IR cover down and pulling the plastic side tab which holds a button battery of size 2032. You can get a 10 pack of these batteries for $1 of you look on the website which sell cheap LED lights.
Here are some links and the FAQ about backs and such:
http://www.faqs.org/faqs/hp/palmtops-faq/
http://www.acsplmtphp.tk/hp100lx-appointment-file-lost
Sep 12, 2005 | HP Jornada 200LX Palmtop
Jornada 820 and Wireless
It is possible, but you need a notebook PC Cards (PCMCIA) that supports Windows CE 2.11. Most Compact Flash wireless LAN cards need Windows CE 3.0.
Sep 12, 2005 | HP Jornada 820
HP 200LX... Win2k... Software...
The Connectivity Kit will operate under Windows 2000, but only in full-screen mode. It will freeze the display if it is run in a window. You'll need to press to restore it to full-screen mode.
Jornada 820 - WiFi cards HELP
Can you try inserting the card and resetting the unit with the reset button. When the unit is back up got to start>programs>communications>remote networking then make a new connection. Choose dial up connection and select your card.
Internet connection at my e830
To configure the Wireless connection you can use the Wifi connection wizard or setup the connection manually. I hope that you have checked your workgroup too. Also you should check if your IP settings are the same at the router and PDA (dynamic and static IP)! If you have some another device connected to the router remember them when you setup the PDA connection! In the end the MAC address of the PDA WLAN card must be saved in the router!
Sep 08, 2005 | Toshiba e830 Pocket PC
HP Jornada 620LX Logo
241 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
