Question about Palm Treo 650 Handheld
Treo 650 won't sync with Outlook calender on my Windows XP Pro desktop?
The Treo won't pick up any of my calender appointments. When I go into the Palm desktop then custom fields - it trips back to 'do nothing' on the calender. This happens everytime I syncronise.
    Master:
  • 473 Answers
I was tring all the possible ways to resolve the issue. At last got a solution for my problem. Hope this will work for you all. Download the "OutlookConduitUpdater.zip" and install. This will resolve the calender "do nothing" while sync.
Posted on Sep 12, 2005
  • 3 Answers
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Posted on Mar 30, 2006
Fought the great fight, spent hours with Verizon, Palm & Outlook tech support. Brought in The Geek Squad, Geeks on Call; they couldn't fix it but they certainly did know how to charge for their unproductive visits. Talked with the Pres of Sonoma Enterprises who supplies my real estate specific program and he finally directed me to the ultimate solution. Bottom line after spending hours on the web is that Palm conduits suck. Purchased Key Suite by Chappura... problems solved FAST and as a bonus, their attractive screens are more intelligently designed and make the wonderful 650 display shine. Kudos to Chappura, my new hero!
Posted on Jan 19, 2006
No Calendar synchronization between Treo 650 and Outlook Calendar, where conduit is set back to 'Do Nothing' after setting it to synchronize, is in most cases caused by a conflict between the HotSync's Calendar conduit and another application synchronizing the Outlook Calendar. For the case when the conflict is caused by VersaMail configured to synchronize wirelessly with Exchange ActiveSync, the solution is described in Palm Knowledge base Solution ID: 36077 You can access it here: http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=38,E=0000000000244870049,K=2821,Sxi=10,Case=obj(36077) The bottom line is you will have to disable VersaMail synchronization with Exchange ActiveSync for both email and calendar together, if you want to sync calendar with Outlook using Hotsync. If you are not using VersaMail with Exchange ActiveSync, check for another application synchronizing Calendar with Outlook, disable it and retest.
Posted on Jan 16, 2006
    Master:
  • 473 Answers
Was able to fix this issue on mine by re-installing the Outlook Conduit.
    Master:
  • 551 Answers
Just a few thoughts if you have not tried already you might want to try one of the below to see if any fixes the issue. 1. Perform a soft reset on your Cingular Treo - keeps all the data, but reboots the OS. This fixes some intermittent sync issues. 2. Create a new calendar file in outlook - create a test calendar file in outlook in addition to your standard calendar file - do this in outlook under the file menu/folder/new folder and create a folder that contains calendar entries. Then go to your custom set up in hotsync, click on calendar, then change, then settings, then click brose to change the source folder to point to your new test calendar. Make sure you've got a few items in your new test calendar to test the sync. If this works, you'll just have to copy your old calenar entries to your new calendar folder. 3 If all else fails and you can bear setting up the entire phone again, do a hard reset - you'll loose all data and apps - and deinstall your palm/sync software from your desktop and start from scratch as if you're setting up the phone for the first time.
    Master:
  • 551 Answers
A common problem is that Verizon Wireless Sync is set to auto disable the palm outlook conduit for the Treo650 to sync with Outlook in order to avoid duplicate entries. So, if you're using Verizon Wireless Sync, this probably caused your problem. In order to fix this, on the Treo 650 go to the Wireless Sync, touch "Wireless Sync" tab at top left of page then touch "Setup" then "Connection Settings" then "Advanced" at bottom right of page. Check the "Enable other sync apps" at the bottom of the page and touck "OK". BEFORE YOU PRESS HOTSYNC, do the following in order to avoid duplicate entries on the Treo or within Outlook. Go to the HotSync Manager on your computer, right click on the icon and choose "Custom...". Click on (highlight) Calendar, and click "Change". Click on "Sychronize the files" and click "Settings". In "Conflict Resolution" click "Outlook Wins". Close with OK's and Done. Repeat the same steps for Contacts, Tasks, and Memos within Hotsync.
    Master:
  • 551 Answers
Found one answer. I am using Versa mail with POP accounts and one exchange server account. The exchange server sync uncer Versa mail does both email AND calendar wirelessly.. Therefore, it seems to want to force the calendar sync to do nothing on wired sync. I spent an hour w/ Palm on phone deleting and reloading SW on PC, hard resetting hte Treo and it all worked fine. I loaded 2 other email accounts (POP3) and all was fine. THEN I loaded the exchange server account and saw/realized the issue. (Note: They were adamant that I had to delete the SW and reload to reset all the settings... doesn't make sense if you at least rename the backup file. Follow other posts for this to make sense) I haven't had the time to delete this account to see if it makes a difference or if it is set permanently this way. It appears to be working with via wireless connection to Exhange. Just sort of a pain to have to maintain it this way. Will put up another post if ti stops working or I learn more. Good luck.
    Master:
  • 551 Answers
Same set up, same exact problem. originally the system found my contacts and outlook calandar. now it just keep giving me the following errors: The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize I've tried: - reloading the software - changing the sync settings to use the pc over ride - renaning my databook file - upgrading to the latest palm software and anything else I could find. NOTHING has worked. I am thinking about taking the phone back to Virizon. Without the capability to sync my calandar it is not a very useful tool.
    Master:
  • 551 Answers
I FINALLY got my Calendar syncing today (my e-mail address was just in VersaMail set-up with user name, not username@mail.com), so that fixed the Calendar sync problem -- even tho I can't figure out why in the heck e-mail WAS syncing. Anyway, now that I've got it sync'd, it's STILL going back to reset itself to 'Do Nothing'. I've seen another post with the same problem, but no answer. I hope there's a fix for this!
    Problem Solver:
  • 16 Answers
Using the wire cutters/strippers, remove 1 1/2 inches (4 cm) of the outer insulation from the headphone cord. You should find three wires: two insulated wires and one uninsulated wire, which is the ground.
Can you sync the palm calender to a blackberry 8330
if you tell the palm hotsync program to sync with outlook, you can dump your calendar into outlook, and when you sync your blackberry with the desktop manager you can tell it to sync with outlook as well, and that is how you can transfer the calendars.
Nov 05, 2009 | Palm Treo 700p Smartphone
How do i change my ringtone on my Palm Treo Pro Smartphone? I cant seem to change my ringtone at all!
I have synced Gooldle calender withoutlink calender and then ActivSync 'ed to my Palm Pro, the phone calender does transfer the meetings, but all the metings are 1 hr delayed. For instance, a meeting in google / outlook calender at 9am transfers to 10am on Palm - any advise?
Oct 16, 2009 | Palm Treo Pro Smartphone
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
I lost my calender during a Hotsync.
Hi mikeand,
you could check the calendar on your computer using Palm Desktop application. You could restore the data to handheld only if the Palm Desktop show the data you need.
Nov 08, 2007 | Palm Treo 650 Handheld
Sprint treo 650
hi, on the hotsync software (palm desktop) there normally is an option were you can decide what to sincronise and what not. if you go to hotsync (on the top next to tools)and then choose personalise, then look for the calendar and click change, choose the one you think is correct. dave ;)
Apr 21, 2007 | Palm Treo 650 Handheld
Contacts will not sync
I had this exact same problem did everything U discribe. I even change cables stood in the wind facing north and sacrificed a small animal (hahaha) I called Palm, they said do ahard reset. (haha) reinter 24 day of data manually into the desktop, I dont think so. Then I shut down all the conduits but calender. then I set the conduit to have the handheld over-write the desktop. PROBLEM solved!! No data loss No hard reset No re-entering data. I then folowed up with several test syncs in several conduit configs, including test data in both desktop and handheld. hope this helps.
Sep 05, 2006 | Palm Treo 650 Handheld
Missing Outlook Calendar, Contacts, tasks, email after hotsync
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 12, 2005 | Palm Treo 650 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Treo 650 calendar not syncing back to Exchange
I am experiencing the exact same issue. Are you saying that this only occurs with one of your 650s? If so then maybe it is a hardware issue.
Synching using 2 versions of Outlook
yes there will be problem. what you need to do is to install the version of the outlook the same with the one you are migrating from so that it will not have compatibility problems.
Thanks
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
1,267 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
