Question about Kenmore 24032\24036 Top Load Washer
Model# 110 the agitater wont turn but it makes a grinding noise and wont turn freely by hand. the teeth under the agitater are fine. is the transmission worth fixing? can I access it somehow? please help!
  • 5,911 Answers
That depends on if you're willing to perform the steps required to replace the gearcase (transmission) , and the price to fix it. Review the following link, it explains the steps required to replace the gearcase and how to access it:
http://www.fixya.com/support/r699497-replacing_gearcase
This is a pretty straight forward repair job that you can accomplish on your own if you follow the steps required. A replacement can be found at either searspartsdirect.com or repairclinic.com. Just type in your complete model number (located along the wash tub opening under the lid) and follow the links on the next page. The Sears website offers helpful parts drawing to assist you in component identification and assembly. Do some cost comparisons at each site as they both offer competitive pricing. The average cost is about $150. A refurbished one will cost you less.
If you are going to go the route of replacing the gearcase, I would strongly recommend replacing the motor coupling as well. The coupler is located between the drive motor and gearcase and typically wears out. The cost is about $15 or less. The next link explains the steps required to replace a motor coupling, and includes the part number:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
I know some of these steps are repetitive, but it may include information the previous link does not cover. Typically, a broken motor coupling will cause a no agitate or spin problem too. Coupled with the fact that the washer is making a grinding noise and will not spin by hand leads me to believe that your initial diagnosis may be right on. A tale tell sign of some failed gearcases is a honey colored oil leaking from them. If you see oil on the floor under the washer and/or spray patterns along the interior cabinet walls, you can pretty much assume its time to replace the gearcase.
I hope you find this information helpful. If you require additional assistance, please let me know.
Posted on Sep 01, 2008
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Motor seems to be working but fan does not turn.
NEED MORE INFO!!! Make/model of fan would be nice!
Mar 18, 2013 | Dryers
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
I have a Frigidaire dryer model FDE437GHS0 It has been working fine til this morning. If I turn the timer switch to time dry and push the start button it sounds like the timer is turning(or the gears are)...
IT SOUNDS LIKE THE TIMER IS BAD. IF THE TIMER MAKES NOISE IN ANY POSITION AND GRINDS THE LITTLE TIMER MOTOR OR THE TEETH ON THE MAIN GEAR IS SLIPPING
Aug 11, 2009 | Dryers
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
1999 hyundai elantra starting problems
remove the starter motor and check for damage/wear on the teeth of the starter motor and the ring gear teeth on the flywheel.turn the engine by hand while checking the ring gear so as to check the condition all the way around.hope this helps
Aug 27, 2008 | Hyundai Motor 1999 Elantra
Kenmore 24032\24036 Top Load Washer Logo
94 people viewed this question
Sal De
fordexpert
Robert Rankin
