Question about Vacuums
Kenmore canister vacuum #116 5521290
The power stops suddenly then starts for a while after adjusting the swivel assembly until the swivel location moves to another direction.
    New Friend:
I have this problem and I can clearly see a crack in the cord between the floor tool and the cord attached to the lower wand.
Posted on Dec 19, 2012
  • Liz Neal Mar 13, 2017
    I ordered and replaced that small cord from the floor tool to the lower wand.........perfectly fixed now. This is the 3rd vac like this one that had that cord crack.
    President:
  • 1,462 Answers
Im not familiar with kenwood vacs (i'm in uk not us) but usual cause of this type of fault is a fracture in the power cord where it enters the appliance or at the cable clamp. cut 6ins of the power cord and remake the connection
Posted on Sep 02, 2008
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
I have to replace the power head swivel. I have the part. I can't quite figure out how to swap out the broken with new.
I just shot a short video explaining how to replace your swivel neck. I hope this was helpful to you.
Also, here's another repair I wrote showing how to replace the belt, which will help you "crack" the two housings apart on the Kenmore Canisters.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Jan 06, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
if you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Oct 05, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Won't power on.
It maybe cheaper by going to somewhere like the Radio Shack to get a fuse. Take the bad fuse with you and they should be able to fix you up with one.
Jan 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
260 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
