Lcd TELEVISION LOCKED
Switched my tv off it was working fine when i switched it back on it would not switch on manually with remote or by the tv power button the remote is working its somehow locked
  • Aage Lind
    Aage Lind Jan 21, 2009
    Alfaview
    Model NO: 40" Deluxe LCD(HL-4010V)
    It use the same printcard as HP-4200VPM
    Victory sub_ v 1.4 8BARPD002
    and
    Victory main_ v 1.4 8BARPD001
    No sound and no picture. I kan se that the light is working.
    I have treid to pus the reset-button near the Eeprom on the mainprint. It only gave a littel mor light on the screen.
    I think that the set must be locked.
    Can you help my onlock the sreen
    Aage Lind
    Denmark
    aage-lind@↨stofanet.dk
snakehead
  • 1074 Answers
SOURCE: ILO-26HD
take your tv back to the supplier you bought it from let them rectify the problem.i suppose that your tv is still under warranty.good luck.
Posted on Apr 19, 2007
SOURCE: ILO-26HD
We had bought the extended warranty, so we took it back and got a new TV of a different brand. We had to pay the difference, but it was worth it. The warranty even carried over to the new TV.
Posted on Apr 20, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Television "locked"
This is usually a child lock feature and/or a function to keep people from changing your tv settings when company is over. The only way to get it out is to get the original remote and the manual for the set (would help if we knew the model and make) to unlock it. Sometimes the universal remotes will lock them as i think this is the issue here.
Posted on Sep 14, 2007
SOURCE: Samsung LCD "keys locked"
push the menu button for 10 second on the tv.
Posted on Mar 05, 2008
  • 95 Answers
SOURCE: locked tv
What is the make and model number of your flat screen tv.
Posted on Mar 11, 2008
I cannot get my television to power on. I have tried different outlets. The remote only. The power switch on the TV. This happened all of the sudden. The TV is connected to a HDTV power surge protector....
Hi frank, my name is John. Welcome to FixYa. You need to try, what we call a Cold Start-up. What you do is unplug everything, and let it remain unplugged for one (1) hour. Then plug it all back in the outlet and start it up manually. Thanks for choosing FixYa....John
Dec 12, 2010 | LG 37LG30 37 in. LCD HDTV
My directv remote will no longer work t v re programmed it for another tv and works fine the orgial remote will not work either funny thing this happened today after replacing old batteries
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Nov 01, 2010 | Westinghouse SK-32H240S Television
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
Tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Mar 25, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Olevia lcd tv will not turn on.
First you want to unplug the tv for a few hours to reset settings. Plug it back in and then switch the master power switch off and then on.
There is a master Power Switch next to the power cord receptacle, make sure that this switch is on the on position and the blue LED in the front is illuminated (Note: The switch in the rear of the television is in the on position when the line is depressed).
This should get your tv working again. Just needs a good powercycle.
TECH just worked on a tv I just tried it on.
Dec 02, 2007 | Olevia LT32HVM 32 in. LCD Television
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
