Question about Compaq C-Series 2010C Pocket PC
Dead 2010c handheld
My 2010c just quit after it tried to restore flash memory. I get the Compaq splash page but it goes to a blank blue screen Does anyone know where I could purchase the rom chip for this device or have an idea what to do next? Thanks
0 characters
1 Points
Compaq 2010c lcd wiring schematic
Check this:
http://diy-ksoft.com/arduino/578-28-inch-tft-lcd-touch-screen-module-uno-expansion-board-for-arduino.html?search_query=LCD+arduino&results=114
There are a lot of touchscreens for arduino. Also if you want to keep it firmware compatible with what you have, you need to know the model and the interface type for it to get a new one that yill match yours.
Without further details is not possible to help you more....
Regards,
L. Coelho
Mar 28, 2014 | Compaq PDAs
Plz tell me ffrm where i shud download motorockr E6e themes(site..........plz?)
hello dear.......... installing themes on the E6 can be a tricky business and sometimes fatal for the phone. you need to install MPKG installer to do this. for the details on this visit http://www.mototheme.com/Howto.htm. But i strongly recommend that you dont try to install any theme on E6 cause the version of linux EZX which E6 is based on has its own shared memory for using themes. if the newly installed theme exceeds the memory capacity of the phone, your phone will permantly hang and wont do anything. it wont even switch off normally. you will have to take out the battery from the phone. on restarting ur phone, if it hangs again on the motorola splash screen then consider your phone a dead machine. then the only way to bring your phone back to life is by flashing ur phone and installing a new software on it......... which is quite a headache. still if you want to do it. then do it!!! its ur phone brother
Dec 10, 2008 | Motorola Mobility ROKR E6 Smartphone
Not able to power on Nokia 9500
Hi There
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 29, 2008 | Nokia 9500 Handheld
Outbox
Unfortunately the message file got corrupted. You need to hard format the phone but of course you need to back up every important file on the phone memory cuz it will restore yur phone to factory defaults.
Make sure you have a full battery. Remove the memory card and sim as well. Turn off the unit. Hold down asterisk (*) sign, the number 3, and the green call button at the same time then power it on. The screen will flash and you will see a progress bar. It will format itself automatically.
Hope this helps.
Sep 18, 2008 | Nokia 6680 Handheld
Ipaq H3630 how to do a hard reset
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Aug 29, 2008 | Compaq iPAQ H3630 Pocket PC
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
Locked Compaq 2010c
I\'ve bought this on e-bay but I can\'t run it as it requires a password. is the any way I can reset the computer and run it or a "back-door" password? it says administrator loutout mode is in force and thta i have to use a c-series unlock utility to gain access.
Oct 25, 2007 | Compaq C-Series 2010C Pocket PC
Bootimg
U just remove memory card and then try to boot it up,,  and once save ur data in ur memory card only then restore ur phone then try,, aftr that flash ur handset from nokia care.
Sep 18, 2007 | Nokia 6680 Handheld
Compaq C-Series 2010C Pocket PC Logo
20 people viewed this question
Top Compaq PDAs Experts
Cosma Papouis
Cosma Papouis
masterwest
Level 1 Expert
Kolbrun...
Are you a Compaq PDA Expert? Answer questions, earn points and help others
