Question about Proscan PS35660 TV
Proscan ps35653 will not turn on after recent move
A Proscan ps35653 was new in 1993 this set has only been used one day out of 30.,... once a month it was moved to another home about a month ago.... Now the TV system will not turn on ...... I've not found the owners book yet.... but think that this system can be RESET by using the front panal.... It there anyway to reset this? if the power supply is bad what might it cost to have fixed... from what I've found online this model has had power supply problmes... If so why were they not recalled?
Mr. Sanchez
San Diego, CA
Email sdabqaes@cox.net
  • sdabqaes Sep 01, 2008
    No comment regarding system reset ? I recall that this model and others proscan TV's could be reset by using the front control panal ch,- ,+, vol, -, + power, etc... can anyone give me the factors of reseting proscran/power supply
    Do you know of anyone in the San Deigo that works and supports proscan TV systejms
  • Proscan Master
  • 19,396 Answers
As far as I know there is no reset procedure involving use of the front panel. Service reset procedure is done with original remote.
By the way if it does not start you cannot do areset.
Check fuse on power supply unit.
Posted on Aug 31, 2008
  • 37 Answers
If its the power supply it could cost anywhere between 50 to a couple hundred.
    Master:
  • 521 Answers
Yes it could be the problem of power supply.
  • 1 more comment
  • tech expert12 Aug 31, 2008
    or the problem of moisture on the power supply board due to rare use.it not helping tv to start properly.apply blower on the power supply board.
    the cost of power supply board is near to $ 250.
    but call the service center to replace it as if you will gwt and replace you will not get any warranty for it , and if the service center will do you will get the warranty of about nearly six months.
    thanks.
    please do rate the solution.
    regards,
    fixya expert team.
I have an RCA proscan tv, CRT type. My sound has to be turned all the way up to hear it. There is also a low hum whether the sound is up or down and does not change volumn, no matter if the sound is
The ctc169 was the workhorse of the RCA line being used in over 300 models----sounds like a possible audio output circuit---a lot of parts are no longer available and I would be careful having a shop fix a set this old.
YOU "might" be able to get around this with a surround sound system used with a cable box.
Dec 04, 2012 | Televison & Video
I have a RCA Proscan PS35653 that won't power on. I have had this happen before & took it back to Circuit City where I purchased it. They repaired it but are no longer in business. It didn't cost much...
These units are famous for high voltage/horizontal problems which could have affected the power supply. Parts are beggining to be no longer available for these sets. Have a shop give you an estimate before putting a lot of money in it. Thanks for using fixya.
Jan 02, 2010 | RCA Televison & Video
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Nov 05, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The slide to turn on the phone will not move.
Try using the stylus located bottom right. Use finger nail to flick out. Once you've done this select settings and select pen calibration until Done appears on screen this sets the sensor according to your touch!
All the best.
Aug 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Proscan ps35653 chassis ctc169 picture to wide for screen
press the menu button on the front of the tv and then scroll down using the channel buttons to picture format, next change the format from widescreen to standard.
Jan 19, 2009 | Proscan PS36123 TV
Proscan PS35653 TV screen is to wide. I can's see the whole screen. Which is a problem when trying to read something off the tv
to wide to read ? i think u can adjust the horizontal or im buying proscans im trying to figure out what you mean does the print fade from side to side or ?
May 24, 2008 | Televison & Video
Pro Scan On / Off Switch Problem!
Sometimes a power surge or bump will cause the program chip to hang up. If there was no surge or bump, then program chip may be defective. Any case i would return it for another.
Mar 01, 2008 | Televison & Video
Alarm
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps  1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
Jan 05, 2007 | Casio DW9052-1V Wrist Watch
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
Televison & Video Logo
149 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
