Question about Whirlpool Washing Machines
Drum will not turn . it turns ok if i do it by hand then it is ok
  • 639 Answers
Peace Friend,
ngfam1 At your service!
1. It sounds like the coupling connecting the transmission to the agitator is broken !
2.Or the worse case could be the transmission is shot!
How old is the Washer and is it a top loader?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Less water,energy, and detergent!
This puts money back in your pocket and the new machine will pay for itself in only a few years
I am not there to have hands on advice.
But the only way to find and to repair this is,
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Motor smell hot drum will not spin or pump out water Maytag atlantis
Im not an expert, but.Ok, but it wash? The only problem is at spin? if not wash at all:
Disconnect from the outlet, remove the belt, and by hand turn the pump and drum. Its suppose to move with low resistance in both directions, will not spin freely, but turn easy by hand. Do the same with motor. IF the drum and pump moves in both directions, I suspect about the motor.
If the only problem is at spin:
Do the same, but place special attention at the drum when you turn in reverse. Look if you see the brake Disk turn.
Nov 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Dryer drum turns by hand, belt ok, motor hums but doesn't turn duum.
you have a bad motor,change it out,try this,open the door and put your hand on the door switch and with your other hand spin the drum while somebody else hits the start button,sometimes this will help the motor start but you still need to change it out,easy job to do
Oct 12, 2010 | Kenmore Dryers
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
