Question about Whirlpool Washing Machines
Drum will not turn but motor is running. it will turn after i turn it by hand it will run ok
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Things wear out! So is life!
Sounds like the belt needs to be replaced!!!!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I
Posted on Aug 31, 2008
My drum will not spin.
Try to determine , by removing the belt from the motor, if the drum will turn by hand, and if the motor will run with out the belt on it.
Likely the drum will turn by hand, and if the motor will not run alone, either the motor is bad, or the control panel is not telling the motor to do it's job.
Some washer motors also have an overheat switch, that can be clogged by lint, but I am pretty sure your does not.
God bless your efforts.
Sep 08, 2015 | Bosch Washing Machines
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
My ED56 won't start unless you turn the drum by hand why?
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Apr 28, 2012 | Fisher and Paykel Dryers
Tumble dryerdrum not turning when on but motor continues to run when door open
Does the drum turn by hand? I would check the motor belt first
Nov 26, 2011 | Hotpoint Dryers
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Hoover hpe236 drum doesn't turn during wash cycle
Watch the motor when it is supposed to be running. If nothing, measure for voltage across the brushes and across the motor power terminals. Make sure the motor will turn freely by hand. If power is present, there may be an open wire to either the field winding or one of the brushes.
Jul 15, 2009 | Hoover HTC243 Top Load Washer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
