Question about Maytag MAH2400A Front Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
Loud squeaking, but not during spin cycle. Help?
  • gmason319 Nov 08, 2008
    The top seems to have loosened (from the very violent shaking during many loads). That results in squeaking of the top and its mounts. Presumably.
  • 63 Answers
Very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Posted on Nov 14, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
When my washer was on the spin cycle it was making a very loud high squeaking/buzzing noise, could this be the belt and how do i fix the problem? Thanks Crystil
The belt would probably squeak in the agitate direction also. I suspect a tub or clutch bearing is going out. If you find signs under the washer that it's been leaking, the tub bearing needs to be changed. It's a major disassembly job. The clutch bearing may be easier.
Jul 04, 2011 | Maytag Legacy Series Top Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Maytag legacy load spin cycle
It is your main bearing, I don't recommend doing it yourself. You will need a special spanner wrench that you'll use only once. To see an exploded view go to Sears Parts
Aug 07, 2007 | Maytag Legacy Top Load Washer
Maytag MAH2400A Front Load Washer Logo
933 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
