Question about Kenmore 24032\24036 Top Load Washer
Washer won't turn on at all
I have a Roper top load washing machine that will fill up with water but won't turn on into any cycle what so ever once it's filled. The wall socket is ok & was checked, but it's like there's no electrical power to it. The timer doesn't even run down. any suggestions? Model # RAX4232RO3 (was also wondering if it might have something to do with the lid button?)
  • 5,911 Answers
This is a very common symptom of a lid switch malfunction. This happens when the switch wears out. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, you will need to remove the console and exterior casing to access the switch. The lid switch on your model is located near the left lid hinge, and is activated by a small steel rod. Sometimes, all it takes is adjusting this rod by bending it slightly to make the switch activate. If you can get the switch to click or activate by hand, there's a good chance all you need to do is adjust the rod that activates it. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #8318084). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I know the link is for a Kenmore or Whirlpool washer, but your washer is manufactured by Whirlpool and uses the same parts. This is a simple and inexpensive repair if you wish to accomplish this on your own. This total repair will cost you about $15 (if the switch is required). Let me know if you require addtional assistance.
Posted on Sep 01, 2008
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I have a Roper top load washer. when i start it, it automatically starts on agitiate. It skips the filling cycle. model# RTW4100SQ1
It sounds like you have a bad water level switch.The switch is the one you turn to set the water level.
Jun 24, 2011 | Roper RTW4100SQ Top Load Washer
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
369 people viewed this question
Sal De
fordexpert
Robert Rankin
