My mic does not work on my microsoft lx-1000 head set, the audio works through the earpiece but no the mic, i've gone to set up a mic in the windows 7 settings but it does not hear me. I had a turtlebeach headset installed and working prior to the lx-1000
  • Computers & ... Master
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Posted on Jul 30, 2011
SOURCE:
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Mic won't work at the same time with the audio?
Your trying to separate two audio sequences with one through cable the head set is not designed for the standard input jacks to combo they are isolated. You may need to get a mic and headset that has two cables one for the "Pink" and one for the "Green" input to do both. Maybe someone has a better answer or some trick to be able to get two audio signals to work at the same time with one input.
Apr 11, 2012 | Computers & Internet
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
Sep 27, 2017 | Video Cameras
How do I tighten a loose earpiece?
The whole thing is probably plastic and subject to breakage if you're not careful. I've found that gentle pressure on plastic pieces works most times. But--that's the trick. How to get just the right pressure. I'd sure try it, but be careful. Glueing that type of plastic is very difficult. It can be done, usually, by melting the pieces together with lacquer thinner.
Dec 08, 2011 | Razer Carcharias Gaming Headset
Hi this is erum here and I've a head set of Microsoft LifeChat LX-1000 and Microsoft site said its not compatible with win7...
Hi Erum,
The hardware specification for this device is supported on Windows 7 also. The below link has the information from Microsoft
http://www.microsoft.com/hardware/en-us/p/lifechat-lx-1000#details
Did you check if the music is audible when it is plugged.
Aug 12, 2011 | Microsoft LifeChat LX-1000 Headset
I can hear people through my head set but I can't talk to them?? I have brought a new head set but the same still happens. It worked fine before??
Check to see if your mic is muted. If it's not, make sure it's plugged in correctly. If this still doesn't help then perhaps the mic is faulty. Is there any way you can try it on someone else's Xbox 360?
May 07, 2011 | Microsoft Xbox 360 Console
Have Windows XP and Lifechat LX-1000 headset with traditional audio plugs. Can't seem to find the driver (and no advise came with the product!). Only obvious microsoft download was Windows7 and...
Hey! If you try to install this does it work properly?
http://download.microsoft.com/download/F/7/0/F70FBF72-2AAB-4D60-9E49-7B015E8E5851/LifeChat1_4.exe
Otherwise did it come with an installation cd?
Feb 28, 2011 | Microsoft LifeChat LX-1000 Headset
Microsoft vx 1000 i cant get the audio to work on a vista computer
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device - enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
Jan 30, 2010 | Microsoft LifeCam VX-1000 Webcam
My microsoft lifecam VX-1000 webcam will not work on 2009 msn
Connect Webcam
Test your webcam here by hitting "Allow" in the top window and checking for your webcam in the left hand panel
http://www.testmycam.com/
If it works reasonably well
Reboot webcam by disconnecting from USB for a few seconds.
Open WLM ( msn )
Click ( > ) Open menu > Tools > Audio and webcam setup - set up audio by dedicating default mic and testing > Next - make your webcam default and adjust settings > Finish
Aug 26, 2009 | Microsoft LifeCam VX-1000 Webcam
Lifecam video works great - but no audio!
do a cam/mic test in the audio/video settings in the tools tab in yahoo/msn. Then you need to minimise the yahoo/msn screen and right click on the cam icon in the taskbar and check that the mic and cam are enabled and that it is set to allow other programes to take control of this device
Dec 02, 2007 | Microsoft LifeCam VX-3000 Web Camera
Computers & Internet Logo
67 people viewed this question
Alun Cox
