Question about Palm Tungsten T5 - Multilingual Handheld
Want Microsoft Outlook to dominate - two computers
I have a new Tungsten T5, and have synched it with my home and work computer. I don't want my home contacts on my work computer, but do want them on my handheld. It seems that when I do a synch, the changes merge. I deleted the contacts which were added to my work computer, and the HotSynch deleted the contacts off of my handheld. Is there a way to denote that Outlook takes prominence in all cases? I don't want anything in Outlook changed based on the Palm device. Thanks
    Master:
  • 551 Answers
Update dominance in Palm Desktop app. Figured it out! Go to the Palm Desktop application. Click on HotSynch, and then Custom. On each of the four Outlook conduits, click "Change", and specify that desktop dominates, if desired.
Posted on Sep 12, 2005
SOURCE:
My T5 will not synch my calendar in Outlook
Welcome to Fixya
Double check the Palm or palmOne program in Windows. Click Start then All Programs then Palm or palmOne. You should see an icon in there called Sync with Outlook or something similar. Click that icon and the Outlook conduits will replace those for Palm Desktop. Some conduits, like Media/Photos will continue to sync with Palm Desktop, but Calendar, Contacts, Tasks, and Memos will sync to Outlook.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Aug 10, 2011 | Palm Tungsten T5 Handheld
I have a palm tungsten t5 and need to link it to my new computer but I can not find the installation cd. Could you advise where I can download from? Thanks Steve
Here is a link to download everything you are looking for for your T5. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/home/page_en.html
Nov 13, 2009 | Palm Tungsten T5 Handheld
Hot synch to new computer
If you right click on the hotsync icon in your status bar, you can set each of the sync options to "handheld overwrites desktop." That should stop you losing data.
Dec 03, 2007 | Palm Tungsten T5 - Multilingual Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Hotsync with two computers
I just posted a similar kind of problem. With my old M105, this worked fine - Outlook on my work computer, Palm Desktop on my home computer. When I upgraded to Zire 31, I saw that message about 2 computers once during the past week, but never again. I was thinking about using the Install CD again on my work computer to see if there is an option for synching between 2 computers. (synching to 2 different computers seems to be the most reliable backup for one bad synch)
Sep 11, 2005 | Palm Tungsten E Handheld
When synching new Outlook calendar items, a "note" is added to the T5 calendar item
I have the same problem. T5 Win XP Home HP Pavilion Desktop Outlook 2003. It seems to only attach the blank notes to recurring appointments. Delete them all (which is annoying) and they come back after a HotSync
Sep 11, 2005 | Palm Tungsten T5 - Multilingual Handheld
Using treo 600 and tungsten t5
Creating your own profile on each selecting that profile when synching
How to synchronize outlook
Switcher.... Inorder to sync your handheld with Outlook you must have outlook conduits installed. Follow these steps to have an outlook conduits installed. 1. Place the Desktop Installation & Software Essentials CD on your cd-rom drive. Wait for it to finish its autorun 2. At this point you'll be presented wth a flash window which contains certain options you can choose. 3. Click on "Change your synchronization method" 4. Click on "Use Microsoft Outlook to ...... " 5. Click on "Yes" 6. Click on "Done" 7. Restart your computer inorder to refresh the new settings. You can now use Microsoft Outlook to synch your appointments, contacts etc..
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
Palm Tungsten T5 - Multilingual Handheld Logo
97 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
