Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Bosch f/freezer KGV3128
The motor does not switch on until the temprerature is up to about 10 celsius and our milk starts to turn. I can sometimes restart it by switching off for about 10 secs and then switchng on again and all is well until the next cycle. After restarting we hear a series of clanking noises not unlike the sound of an ait-lock in the central heating (which in this case it is not).
  • marycain Dec 09, 2008
    I have tried switching off and on when fridge-freeze goes dead and temperature rises till contents are barely cold let alone frozen. This works occasionally when the fridge runs for ages until the temp hits rock bottom. Have pressed all the buttons but now it is simply pot luck when the freezer might or might not work. It is so temperamental. Poor show for an expensive outlay. Bill.
This is a quote from the John Lewis Freezers Buying Guide which basically says keep your freezer in the house where it is warm, otherwise it won't work :)
http://www.johnlewis.com/Magazine/Feature.aspx?Id=39
Manufacturers do not recommend you keep a freezer in the garage or any other outbuilding, as it may have to use much more energy. Most models require a minimum ambient temperature of 10°C (50°F) to operate efficiently. If the outside temperature is any lower, the freezer will struggle to keep your food chilled – it may even start to defrost. If it does break down, the appliance may not be covered by the guarantee.
Posted on Jan 05, 2009
  • Rose O Jan 05, 2009
    http://www.johnlewis.com/Magazine/Featur...
What is ideal freezer temp setting ?
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
hope answer the question
thank you
please vote!
Aug 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to set temp in the freezer box
dear sir/madam
please find out temperature control switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
thank you
please vote!
Aug 13, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Bosch KGV3120 fridge freezer , compresor not cutting in occasionally and food in fridge gets warm , food in freezer gets a little soft. all lights running.If i unplug /switch off & re-start the unit...
I am not sure but just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge freezer smells of burning after milk leaked in fridge smoke came out and tripped switch whats the matter with it
I believe the milk leaking and the burning smell are isolated incidents. It would appear that your compressor is running without a full charge. I would suggest not using this unit until you can get someone in to check it.
Sep 04, 2009 | Bosch Refrigerators
Fridge not getting cold Bosch KGV36390/05
Hi: It shouldn't need a recharge as your freezer is cold, and that's wher the fresh food section gets its cold from via a fan. If your vents are blocked with too much food in the freezer this will happen. If you have a problem with the defrost heater or timer frost will build and block the port to the fan, causing a warm fresh food section. If the circulating fan is out your f.f. section will get warm. It's a small fan not to be confused with the condenser fan below (at the grill.) Here's a question for you. Did the fresh food compartment work for the first week or two? That's how long it would take frost to build and jam the system if your defrost system is out. If this is the case you can unplug it and put your food in a cooler. Melt the frost with a hair dryer carefully avoiding plastic components. It will then work for a week or two before it fails again. It will get you buy until you get service. If you do it yourself... Look for the defrost heater in the freezer and see if the coil of wire in the glass tube is broken. You will need a service manuals or a parts list with a diagram. Sears parts on line has a good database of parts and diagrams. Hope this helped, Jeff
May 31, 2009 | Bosch Refrigerators
EAM3500S will not froth milk ?
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and flavorless. Use 2% milk or half-and-half. It should be cold (very cold). I put mine in the freezer in a steel frothing container for 5-10 minutes before use. Just barely submerge the wand (about .25") and turn on the pressure. It should sound like tearing paper (not like blowing bubbles through a straw). Do this until volume increases to around double (if you have a frothing thermometer, it should be around 100 degrees F). Now submerge the wand farther and tilt the cup to create swirling (this is called stretching & sweetens the milk). This should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk into a steel cooking pot (I use a saucier for large groups) and put it in the freezer. When very cold (ice forming) put on stove. Whisk briskly while heating up on medium-high. It will create fine foam & stretch the milk at the same time. The bubbles will start big, but become finer as time goes by. I test by stocking my finger in & going until it feels nearly scalding & remove from heat. Just use a ladle for he milk & a spoon for the foam.
May 03, 2009 | DeLonghi Esclusivo Gran Dama EASM6600...
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Hi
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
233 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
